after some messing around I have managed to get the HD mount that was supplied to work
ended up torching out the OEM bracket to clearance the adjustable mount and afterwards it bolted right into place.
gave me a bit of relief knowing everything is starting to line up.
the plate coming off the doubler I cut and had rewelded back in 2015 ( decided to change the clock angle of the tcase, but changed it back the next day, so I cut it and jammed a  log under it lmao) it will be remade and will tie in to the OEM trans mount.
still have to remove all of this and install the real thing.
  • Replies 152
testing the electrical was a success,
added some leads to the block and some jumpers for the rest and It had power.
everything works!
power mirrors windows locks, dash gauges dimmer dome lights hazards sending unit blower ect.
I do have to modify my brakebooster a bit more to get the brakelight switch to work properly.
initially the door locks were non functional, after a bit of diagnosis there was no 12V power.
with it pinned in the fuse box they worked like a charm. after a bit of digging I found the rest of the harness (it was originally from a 4 door, so it was tied in with the rear drivers door/power seat harness)
with that plugged in to the correct spot in the fusebox it worked as it should
new gas tank showed up!
the weight difference between the two tanks is impressive, the one pictured on the right may have a slightly higher concentration of rust scale and sediment. currently using that tanks sending unit for harness testing
picked up my other tanks from storage and started hunting for my good pump/sending unit
first one open didnt look too promising, I was legit thinking I ruined all my sending units by leaving them in the tanks after seeing the condition of this pump.
much to my relief the next one I popped open was pristine and also the one I was looking for.
I am not sure where I pulled that first tank from, but it sure has seen better days
out of all of the pump assemblys pulled, they were all slightly different, some close but not identical.
As to why I pulled all of them from the tanks? I would like to downsize a bit, four out of five spare tanks are 100% junk and take up more room than they serve purpose, they will be part of the over due scrap run
all my oil showed up!
here's a before and after of the ol' engine bay.
fuel tank hooked up, lines primed. no leaks
rockers/pushrods removed and everything liberally coated with driven assembly grease.
oil pan removed and cam/distrubitor gear re lubed as well
added some good ol' soap to the water to modify the surface tension
then added my cheapo burp-o-matic to the system.
Aux fan jumpered to Ignition it was go time!
starter did not work. tried three different ignition switches an no luck
hit er with a screwdriver and it afterfired. FIRST SOUND OF LIFE!!!!
checked TDC #1 and was 180 out. restabbed the dizzy and it fired right up
30 mins of cam breakin done.
don't mind the powersteering pump groaning. my helper forgot to monitor the levels while i was varying rpm
BUT ITS ALIVE!!!!!
pulled the oil pan and cut the filter, everything looks okay.
currently diagnosing no crank from ignition. traced continuity to solenoid from switch and from starter to solenoid. either a ground issue or +12v supplied. shouldnt take too long to fix.
running a little lean as you can see in the headder. have a friend who went to 80 lb injectors on his mustang, so he has a mint pair of 40lbs up for grabs. will toss those in and see if it helps.
need to get a wideband o2 sensor and inculded accessories in the long run
16 hours ago, neohic said:
Hell yeah!! :jammin:
yeah I am pretty stoked!
figured out the no start
simply overlooked the fact that  the harness came from an auto XJ
it is currently looking for Park
now that the engine runs, cam broken in. it is time to finish the wiring
sorry for some photos that are not landscape my phone was on something. I know potrait photos are terrible :(
Brake light switch
I have purchased the dual diaphram booster, which to my surprise or lack there of.
Does not work with the renix pedal set. now, a sane person, would have probably just bolted in the HO pedal set with the revised switch location. it would happen I even have one :laugh2:  but did I use it? no way!
I used a unibit and stepped the center bore two steps larger. not sure what the diamenter ended up being. but it was just enough the bushing snugly went into place with a bit of a squeeze from some knipex.
bolted that all in place, no dice, the switch was just flopping around, out the booster came again.
it needed the old blob and grind to allow the switch rest in posistion and have a slight preload on it.
and this is what I came  up with. ugly, yes. but effective? very
legit just eyeballed it and thought this should be good enough... and much to my surprise it was! first try. switch works perfect.
Throttle Posistion Sensor
During cam breakin, My headder may have been A little warm. so much so the TPS connector (which I had mindlessly tucked through A nook in the intake manifold and dangling right about said headder) had melted. Which I could smell burning during the run, the friend I had watching the engine bay didnt catch it, which is no big deal.
digging into one of my harness boxes I depinned a new 3 pin connector and re pinned the harness into it.
Reverse/4wd
the harness was from an auto XJ oringinally, so I had to thin it out a bit.
at somepoint I depinned the AW4 specific wiring right out of the harness. and was left with a bunch of wires stuffed into this connector.
which to my surprise I at onepoint knew about the starter signal wire and had even labeled it
I ended up pinning the part time 4wd and fulltime  lighting together so both of them come on at the same time since I'm not running a 242 (which I have one! have been toying the idea of putting it in the black mj for like 7 years lmao, maybe oneday)
Ignore the extra grommets under the connector. they were too small and I had to run the proper size one over the pins. they will be removed when I wrap the harness.
Stealing 2 pin connector for the reverse switch
I was going with oem color scheme for wires. but the wires I had were a smaller gauge and I said F it, no one is ever going to see it. and used the wires out from abs circuit becuase that junk aint ever goin in.
trans harness is almost done, just need to wire in the 4wd switch once I have the doubler and tcase back on the bench. I will not be using chunks of loom as pictured. it will be replaced with a new single piece.
just for laughts, I put a tcase on the back. oh I wish it was that easy.
but noooo. because  doubler.
AUX RELAYS
there is so much free power and unused relays in this country edition wiring harness I am going to pin it all into my aux relays
the red wires are fusible links direct from the solenoid.
and theres alot of them in the engine bay unused.
H4 upgrade
linelock
foglights
fan
onboard air
amazon had a good deal on a 100 pack of terminals. they are slighly different. I will have to grind a little bit off of either side of the top nub and they should work perfect.
more on that later
Door jam Switch/Interior lighting
over the years I have heard the XJ door switches do not work.
did not think much of it, until now.
straight up thought it was just due to the wiring/connector design and that I would be in the clear since I rewired everything.
That is not the case!!
they are physically TOO LARGE to fit
out came the dash harness to replace the circuit (I hate cutting wires if you can just depin the entire thing, I know soldering is acceptable. but I think it is lazy and hoaky to deilberately cut your wires to do a splice repair when it takes a few more seconds to run an untainted wire.)
removed the correct harness from another dash and installed it
and xj lighting now on the ground (speaking of the 242, its right there! above the bucket)
Start of Dash Repairs
I decided to change the interior to navy blue!
the only thing I am missing is the back pannel under the rear window, which I will SEM the correct color.
The dash I have, is in rough condition internally, mounting tabs are gone and the headlight switch mount is broken.
but it is navy blue, do you know how hard it is to find that color where I live? I have 5 grey dashes and only one blue.
started the repairs, need to grab some of the correct - of rivet for the brackets.
headlight switch on removal destroyed the piece it mounted too.
so I took a roloc and buzzed the remaining off until flush with the rest of the pannel.
from a donor dash, I removed the new part cleaned it up so all it had left was the extrusion you see from the front.
taking some 240 grit sand paper and sanded it flat until it was close but still had some shoulder for it to bond too
a red cap from a new battery terminal fit perfectly in the hole to line up the new part.
I did mess up on the clocking angle and it is a little offcentered. I have gotten lucky any more and it would interfere with the dash vent. but it works!
I did plastic weld some spots of the shoulder aswell for added measure.
and here is the overall alignment in the front!
turned out not half bad. you can see the scratch from who ever removed the retaining nut before more than you can see where it has been bonded.
happy with the result, here dead on you can see my keyway clocking is off. the fix would be to put a notch further over for location, or just don't mess up in the firstplace lmao.
2 hours ago, A-man930 said:
Labor of love.  Nice work :L:
Thanks A-man, it really is.
honnestly, if nostalgia wasnt such a thing I probably would have never gone this indepth.
I know I have said it time and time again.
but Robert Bryce built the original poor mans stroker in the early 90's, thats where the term came from for the 4.0L
this is infact THE truck and motor from way back.
the early days of the web forums, back when people wrote pages of trip reports and had web spaces dedicated to their craft.
there was no aftermarket support like there is now, back then you just had to make it youself. there was alot of firsts Robert "Rye Guy" had done.
to building custom suspension
making home made tcase doubler/sectorshaft that has still held up to this day
and making the famous "jeep poor mans stroker"
I am sure there is more
all of which I speak of has now dissapeared from the internet as a new wave of fresh content and architecture flushes out the old.  the only  place besides CC to even mention is jeep40performance
I am sure  Pete M could agree,
reading those trip reports and seeing all the pictures really got me into comanches!
then one day I get a message saying "hey I know where the truck is, he will sell it"
now this is no exuse why its taken me so long to finish. the older I have gotten the lazier it is to be.
but hearing that motor fire up for the first time in over half a decade has gotten me locked in.
I modified the terminals I picked up to work with the relay blocks, they ended up working so i buzzed about 30 of them down
mocking dash harness into its new home
at this point I was wiring in the relays for my aux systems and the main harness was bugging me
so I got to de pinning the entire harness out of the builkhead connetor
after a while of detangling I just started pinning everything back intoplace making sure not to cross wires
and here is what I am left with. much nicer.
harness now bundled i'm not actually usuing electrical tape, I will be cutting it all off and replacing it with some harness wrap.
back to wiring in the relay bank before I went and straightened out the harness.
I had a few male/female connectors lying around that matched the front clip, so I started making an adapter for it to be plug and play, sadly I can't use the female end to the front clip since I just cannot find the terminals
if anyone has p/n for 12 awg wire terminals for the connectors pictured please comment them
here you can see the difference in the wire gauge.
I will be running the same gauge in the front clip harness as well.
most of the relay bank assembled.
once the new connector for the front clip shows up i will shorten the two fusible links to match the rest.
here is where they will live.
the stock grounds for the relays was like a gaint spider nest. I will be adding a few common ground studs throughout the engine bay and grounding everything to those.
essentially those relays control HI/LO beam, foglamps and the aux radiator fan
just need to wire in the compressor and linelok  but those will go on the passenger side of the jeep
plastic repairs are all done, dash is now somewhat useable
atleast it wasnt as tedious as doing textron ducting repairs
back to cutting parts out of the donor dash
took me a bit to decide how I was going to blend the new peice with the old and this is what I have came up with
after drilling some new holes and celco'ing in place I bonded the two together and then added some rivets.
disregard the plug in that appeared in the middle, my original plan was to add a rivet there. so i used a spotweld cutter and removed the top layer. after I drilled the center for the rivet I realized there was a big void between the brace and where I wanted to fasten. hence the plug
I do have another Idea for that hole, I have this old landcruiser inclinomoter, yes sadly not the one with the altimiter.
but the wires need to go somewhere. and that is right behind the area I am going to place it.
maybe oneday I'll get to drive this again....
but for now I will keep posting pictures
been a few days!
headlight relays fit perfect beside the airbox! (need to add the little grey clips that hold the back of them tight)
you can even sneak an extra one under the renix diag ports
headlight harness is done
you can see the wire beef
connectors showed up
engine bay is looking better, no more jungle of wires.
need to shorten the temp sensor wires, add the onboard air stuff. delete the balast resistor (it is removed. just have it jumpered. but will solder the wires together. doesnt do anything anyways)
putting the harness in the dash.
had it in and all wrapped up before I realised the clock I want to use (the quartz one) was lacking the wires to function.
 pulled another harness out and robbed the wires.
the battle of the motors has begun....
and finished. in rapid succession.
the winner recieved new bushings.
dash all buttoned up. all switches functional. need some custom switch placards.
cab fully wired. time to cut my floor and turn it into an access pannel
well the clearance washers worked boys!
our clearance is clearancing!!!! no cuttin for this guy!!!!!!!!
clearance washers in action
and removed after adequate clearance achieved
all jokes aside,  IT CLEARS! I can't believe it. it is extremely tight but its doable
I would also like to redact statement two on page 5
"2. the ironman 4x4fab xmember is so wide regardless of the doubler it makes it extremely difficult to install tcase/trans at the same time. to the point I am cutting the floor out I have made and turning it to an access panel"
it actually clears perfect with the doubler.
granted I still need to make a custom driveshaft for the front
thinking if all goes well, I can maybe take it up and down the street in a week or two. brakes have to be done first. not much flat land in these parts.
now with all the empty casings out. time to work on the transfer cases.
I have acquired an np  2005 241 D I was planning on using because it has bigger internals  than my current np241 AND supposed to have a 6 planetary gear setup.
after taking it apart and examining carriers its only a 3 planet.
what a shame.... I tried to put my 6 planet in, and it didnt fit
so I tore open the 99 np231 J i had lying around to use the casings and stuff my  orginal np241 internals into it.
that also means, no machining on the legendary homemade sector shaft required!
there were few that believed it would hold up. but 30+ years, i'd say it has done well
starting to mock up the doubler and set up hi/lo shift rail (i destroyed the otherone being dumb years ago)
made the new shift rail for the doubler
you can see i straight up butchered the old one years ago
while getting ready to drill the hi low detents I noticed some inconsistency in how it was engaging between ranges
it ended up being the shift forks bore is forked, allowing it to shift side to side on its own
I will have to get it filled and rebored and add about 1/4" of shoulder on either side to prevent it from happening again
remember this fork was made about 30 years ago. its proven itself. it works...
better shot of how the bore is oversized
picked up some blue stuff to clean the casings since they were oxidized and I wanted to see if it there was any hair line cracks (yes i could have when it was oxidized, but it looks better lmao)
went from this
to this
and here it sits, waiting for new bearings and seals + the shift fork to be machined.
getting closer to being able to connect a driveshaft!
I need to tie in the transmission mount into the doubler bracket still
I want to make a spring loaded drilled/pinned shift rail instead of ball detent.
any suggestions?
I have a hardened pin that held the original fork to the shift rail I am using that would work perfect,
just need to design the rest.
PS if you buy a snapon box, don't get the rock gaurd top its horrible. it will peel
on second thought DO buy your box with a rockgaurd top, and then warranty to a stainless for free like i did!
here is a crude drawing on the shift lock I want to make.
after looking aound the garage I have found enough junk to start building it
I want to use this hardened pin that actually came out of the shift rail, two posts up you can see one of them still sitting on the front output selector rail or what ever its called
and for those who are wondering....
no I am not a complete savage. I do have a nice work surface for doing important stuff like final assembly with bearings.
that other one is nice because I don't have to care about mucking it up
working on the shift rail some more
needed to drill a hole for the shift lever and I wanted it to be as straight and centered as possible
best choice would of been to walk down to the other end of mydriveway to my neighbours ( we share land entrances, and honnestly its been great, he has every tool I don't and vice versa, I don't charge him for work so  I have free rein over there)
but I was feeling lazy and I had an old air fitting lying around that i ground the bottom of until it matched the profile of the rail.
afterwards I put like half a stick of hot glue on the fitting
it actually worked!
next step was to tap the bore where the hardened pin came out of, to accept the new bolt for the fork.
which was conviently sized for a 5/16 tap
about 10 mins of slow going and it made it through, I could have gone quicker but it was fighting so much I had to break out the large tap handle and I didnt want to break. something about the metal being hardened still bla bla bla
I ended up drilling the fork out to accept the new 5/16 bolt, which was double the size of the old one.
just like that all the slop is gone, and it shifts nicer than I have ever felt it shift since I have owned this truck
I havent brought it to the machinist. after assembling it I am scared too.
I feel that it could cause me more greif having just one part machined perfect, if in the future it comes back to haunt me I'll eat my words and let yall know.
and testing the ranges with both reductions installed
left over junk equals great work stands and training aids.
I dug around in my chucks of metal and came up with this.
tied the doubler brace into the transmission mount so now the basket it complete
its tight but it fits!
image.jpeg.6a1524a9e98d28efdf04d4b153a97bb4.jpegimage.jpeg.9bf60ec6010456ccfaa6f6fca29e2b29.jpeg
I did similar for my doubler mount:
https://comancheclub.com/topic/44929-1990-short-bed-resto-tdi-3-link-coilovers-doubler-jk-axles/?do=findComment&comment=739412
21 hours ago, A-man930 said:
Man A-Man!!! you do amazing work.
what I could only dream of doing if i had access to those tools (id probably break and end mill first off)
here I am with a zip disc and grinding wheel
started fitting the carpet. had it where I thought was good, and guess what it was off.
pulled it over to the drivers side and its a biiiit short on the passenger (my own fault) its like a 1/4" away from being picked up by the screws that hold the rocker sill plastics
man I need new seats
here I am with a zip disc and grinding wheel.
Well thanks for the compliment, but sometimes I'd like to trade "amazing work" for "actually driving".  Good work on yours, I'm jealous of how much you're getting done.
And I've broken plenty of tools on these machines!
I'm realising (not quickly, because its been 6 years) that no one is going to finish this truck for me
day after day of waking up and seeing no progress magically happen made me think the night shift has been slackin..
finsihed up the carpet. like I said its not perfect. my floor pans in the rear have no dip like oem, I went straight flat pan so theres a bit extra carpet behind the drivers seat.
I swear I had a navy blue glovebox cover, maybe its sitting beside the 4 relay cover fasteners for both my trucks
couldnt find it
for now the OG is back on
at somepoint the lock broke, and I am uncertain if i cut the one latch off but it sure was zipped off at some point
It looks like it was taped and epoxied to make it work again, neither did anything.
good vs bad latch assembly,
to remove you just remove the plastic bezzle and then pull up on the scissorlink, the latches will just pop out from spring pressure.
then assemble the way you took it apart. don't forget the little bushin's underneath the latch release
and now onto doorcard repairs,
blue very rare, once uppon a time I had a set, and that is where the map book holder came from, wish I knew that I would rebuild the truck and need them now for the present day.
but my god are these things expensive (not really, but per card $100-200+ canadian + shipping + taxes + import +duty adds up) so guess they are getting repaied
bearings and seals arrived!
messed up and ordered two fat input bearings instead of a fat and skinny
I think I have too many rear output seals also, they just appearing
replacing the rear output bushing
output flanges resealed
this hands down was the most stressfull bearing to remove. ended up just tossing a washer in the bottom and went to town with a 1" rotary file. once the wall of the bearing was thin enough it just imploded and I pulled it out.
replacing all the needlebearings felt like a downgrade honnestly, the new ones have half the needle count and plastic cages to take up the space. we shall see how long the last
the 241's syncro dogs had a bit of crud in them
outputshaft/syncro assembly after all the oil galleys got a good douching
starting to put things back together
was having some issues with the tcase shifting between ranges
ended up tossing in the shift fork from the 80's gm 241 and the shift collar from the 2004 241 which for some reason is shorter than all of the others. I have 5 other shift collars and they are all the height on the left.
thing worked flawlessly, HI 4HI N LO. full engangement of splines in HI and LO
installed the spedometer gear and oil pump and closed er up
left myself a friendly reminder
figured out the doublers shifter,
just need to add a cable guide through the top of the sping detent cap.
the pin from the shift rail
shift lock ball
spring from fm radio antenna coupler
crimped cable
oxy fuel brazing
I ended up shortening the pin, and using that  231 casing dowel on the right (below the electrical tape) as a bushing for inside the bore ID and OD worked out perfect
another air fitting drill guide
here you can see the rest of my frankenstien shifter.
bike lever and mill spec wdg clamps lmao
and it in action!
like i said before I ended up using that dowel as a bushing for when the pin is locked in which I made after this, it straight up worked perfect and took away all the slop from the fork. that lever on the otherhand, it has character
