91Pioneer Posted December 11, 2013 Share Posted December 11, 2013 OK well I've seen the discussions on replacement rocker panels. Some folks used the Sherman ones that fit over the existing rocker which is pretty much a fail. Also, I know there are a few OEM XJ 4-door rockers on the Interweb still, in addition to full replacement aftermarket ones with the taper at the front, etc. So my question is this... has anyone here actually taken a 4-door XJ rocker, modified it to fit the MJ and have pictures to show how it turned out? I read there is a bit of trimming at the very front behind the fender. No biggie. I know the XJ & MJ OEM rockers taper out as they go down the length. So I'm trying to figure out if the taper at the rear edge of the front door on an XJ rocker is identical to the taper of the rear edge of the door on an MJ. If the taper is the same at that point, theoritcally you could make the replacement work fairly easily I would think. Link to comment Share on other sites More sharing options...
dave92cherokee Posted December 11, 2013 Share Posted December 11, 2013 Not sure if the taper is the same or not but i know the MJ rockers are about an inch taller than the xj's. I found that out when I was working the quad cab which is why I just the rockers out and going to weld in 2x6 box tube. Link to comment Share on other sites More sharing options...
91Pioneer Posted December 11, 2013 Author Share Posted December 11, 2013 ... the MJ rockers are about an inch taller than the xj's... oooh that is bad for my plan... how can the fender and door be the same and not the rocker height? Link to comment Share on other sites More sharing options...
dave92cherokee Posted December 12, 2013 Share Posted December 12, 2013 The fender and door are the same but the rocker extends down further. So when I lined up the pinch seam inside the door frame the comanche rocker was 1" lower than the xj. That's a top view of the rockers which is middle of the mj door and middle of the xj rear door. Link to comment Share on other sites More sharing options...
91Pioneer Posted December 12, 2013 Author Share Posted December 12, 2013 Thanks for the pic. Do you think the point where the rear of the MJ door and rear of the front XJ door would be closer than that? p.s. Do you have a bunch of pics from your build somewhere showing all the work you did? Link to comment Share on other sites More sharing options...
dave92cherokee Posted December 12, 2013 Share Posted December 12, 2013 Yah just went through and updated the thread over here as I've received ALOT more help here than NAXJA. http://comancheclub.com/topic/23573-beginning-of-1993-cheromanche-build/ Link to comment Share on other sites More sharing options...
91Pioneer Posted December 13, 2013 Author Share Posted December 13, 2013 Here's the money shot: Crap. Well I might be able to use a XJ rocker, cut out the parts needed and patched... Link to comment Share on other sites More sharing options...
glundblad Posted December 13, 2013 Share Posted December 13, 2013 This may or may not be of any help but I didn't do any of the body work on my MJ. A body shop did all of it. They used XJ rockers and it turned out great. Link to comment Share on other sites More sharing options...
XJ 2000 Posted December 15, 2013 Share Posted December 15, 2013 I am going to attempt it. We have a 4 door xj and the Comanche that we got has no passenger side left to fix so we will do both sides. I will document as best as possible. Scott Link to comment Share on other sites More sharing options...
91Pioneer Posted December 15, 2013 Author Share Posted December 15, 2013 Please do, Scott! Link to comment Share on other sites More sharing options...
91Pioneer Posted December 22, 2014 Author Share Posted December 22, 2014 I am going to attempt it. We have a 4 door xj and the Comanche that we got has no passenger side left to fix so we will do both sides. I will document as best as possible. Scott Did you ever try this? Link to comment Share on other sites More sharing options...
Jeepman Posted December 22, 2014 Share Posted December 22, 2014 I used the 2 door or 4 Door XJ Stamped Steel Rockers for my MJ... Previously used the el cheapo rockers that only lasted a couple years... This is the Before Paint Stamped Rockers installed... They are the Perfect fit but obviously need to be cut down to fit Image Not Found These are the exact ones I used... Link to comment Share on other sites More sharing options...
91Pioneer Posted December 22, 2014 Author Share Posted December 22, 2014 Jeepman, do you remember the brand that you used or where you got them? Those fit like OEM, I'm impressed! Obviously cut down but wow those would definitely work. They're obviously not C2C brand, those are crappy ones. Link to comment Share on other sites More sharing options...
Jeepman Posted December 22, 2014 Share Posted December 22, 2014 I am an Offroad Shop and buy them thru my LKQ Keystone line but any LKQ Auto wreckers should be able to get them for you... They are not the cheapest option out there but I think they are one of the best options at least for my application anyways... RRP870 Passenger side RRP871 Driver side They Retail for $132.00 CDN so not sure what they will be for you locally but I would expect probably somewhere in the same area... Link to comment Share on other sites More sharing options...
91Pioneer Posted December 23, 2014 Author Share Posted December 23, 2014 Thanks Jeepman, CrossCanadaParts has them listed for $117.20 with stock in Winnipeg. When I get closer to the time of needing them, I will talk to a local body shop to see if they can do any better on pricing (and I might not have to pay separate shipping if they order with other stuff, who knows). Did you install them or did you have a body shop do the work? Link to comment Share on other sites More sharing options...
Jeepman Posted December 23, 2014 Share Posted December 23, 2014 Thanks Jeepman, CrossCanadaParts has them listed for $117.20 with stock in Winnipeg. When I get closer to the time of needing them, I will talk to a local body shop to see if they can do any better on pricing (and I might not have to pay separate shipping if they order with other stuff, who knows). Did you install them or did you have a body shop do the work? They are the same Company Now as LKQ Took them over as well as Pro Body Parts... I just checked the site and they list them for $132.39 must be a location thing as they list them as in stock in Brampton... Either way they are a great product... https://ecat.crosscanadaparts.com/base/welcome.php?year=1998&make=JEEP&model=CHEROKEE_(MIDSIZE) Where are you located as I can sell them for less then retail if your near by Stoney Creek/Hamilton area... I didn't Install these ones myself but Originally I gave him the Cheapo ones and he didn't like them so I sent them back and ordered these in and I observed him mocking them up and they fit near perfectly.... Link to comment Share on other sites More sharing options...
87Warrior Posted December 23, 2014 Share Posted December 23, 2014 I had the same experience with my body shop. Threw the C2C rocker in the trash. Per direction from my bodyshop man, I ordered rockers from Auto Parts Network (APN). (on the right, obviously) Since I have no body work skills, I let the professional take care of it I believe he used the outer part of the XJ rocker and grafted it into the existing sheet metal. Link to comment Share on other sites More sharing options...
91Pioneer Posted December 23, 2014 Author Share Posted December 23, 2014 At the beginning of this thread, dave92cherokee showed some XJ rockers that did not fit well at all even though they seemed similar to OEM, like these Keystone ones. His situation however was grafting 2 different vehicles together, not just a rocker replacement, so it's a little different scenario. I wonder if he was using OEM or what? We already know that C2C is nothing but trash, however I'm beginning to think that there are some differences in the OEM-looking ones as well. OEM = best, it's looking like Keystone = 2nd best. The Auto Parts Network appear to be the same product, although APN is likely not the brand but the supplier. It would be nice to narrow down the best brand of replacement rocker to use, so we can help people in the future. The nice thing about this thread is that we're flushing out which XJ rockers really do fit. I'm going to go for a known good brand that Jeepman used, sorry APN isn't a brand. I also checked out the APN site and did not see replacement rocker panels. Link to comment Share on other sites More sharing options...
87Warrior Posted December 24, 2014 Share Posted December 24, 2014 IIRC, the part APN sold was a Sherman. It was a complete replacement rocker panel, not a cover that some folks claim. My body shop man loved the rocker and spoke highly of its fit and finish. That means a lot to me since I know how particular he is and what level of work he does in his shop. Link to comment Share on other sites More sharing options...
91Pioneer Posted December 24, 2014 Author Share Posted December 24, 2014 I was thinking the Sherman ones were crap too, I edited my post to not include them. I will do some research but Sherman may be selling the same parts. I can't see there being more than one or two suppliers of these rocker panels anyway, but we know there are many retailers. Link to comment Share on other sites More sharing options...
pitbull4x4 Posted December 27, 2014 Share Posted December 27, 2014 I found out the hard way and ordered C2C. They were way off on the bottom bends. But we made them work with redoing them. I got the bottom bends straighten out and got new bends to match the front of rocker. He than cut it on the bottom back to match the back bends. Got it fabed together and put on, so now I have rust free rockers Link to comment Share on other sites More sharing options...
Ochie Posted May 19, 2018 Share Posted May 19, 2018 I know the thread is close to four years old but could someone update with information that is current? I'm new to the Comanche Club and many things change in 4 years. Please help a newbie avoid pain and frustration with poor fitting parts. Thanks Link to comment Share on other sites More sharing options...
