Master Or Slave
My clutch has gone soft and barely engages, it has to be pushed all the way to the floor to engage.  Is there a way to determine whether the Master or the Slave clutch cylinder is bad or could there be another culprit to consider?  Its 88 Pioneer, 5 spd w/ 4.0 not sure w/ tranny I have.
Thanks,
It is a 88 Pioneer and I am not sure which tranny I have - probably the less desirable one. I will check the locations mentioned for leaks. I haven't seen anything on the driveway and its a new a driveway so I would have noticed.  I will check the floor boards tonight.  The fluid was a little low but filling it did not help.  This sucks... I have new wheels and tires from a rubicon, just got the adapters and I want to cruise...
Thanks, Gentlemen.
If you have a 2.5/4 cyl, then you have either an AX4 (4 spd) or an AX5 (5 spd).
If you have the 4.0/6 cyl, then would have the BA10/5 (5 spd).
This assumes that the trans have not been changed.
Either way, you have the internal slave cylinder.  That will require dropping the trans if it is the slave.
To check if it is the master, look above the clutch pedal for moisture on the dust cap of the master cyl.  Rub you fingers on the top of the fuse block and check for moisture.  If either is wet, then change the master cyl.  It is an easy change.  Then bleed the system.
Well I checked the floor boards and really couldn't find much evidence of a leak.  I figured maybe things had dried up since I only drive the MJ once or twice a week. So, I pumped the clutch good checked again around the rubber boot inside the cab right before it connects to the pedal.  It was moist but, not like it had a noticeable leak.  I will just replace the master cylinder and go form there. The good news is I went ahead and replaced my wheels - I am very happy.
Before:
After:
Now I just need to be able to ride......
