lostissues Posted August 25, 2013 Share Posted August 25, 2013 I have a D44 and high pinion dana 30, 4.56 gears with a lock right in the 44. both have solid axle covers on them. anyone know what I could get for them?Thanks. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted August 25, 2013 Share Posted August 25, 2013 If both are complete drum to drum, wheel bearings, steering and all....at minimum $800 and someone would be stealing them at that. They are worth $1200 to $1500, but good luck finding a jeeper who will spend that much in one go. it seems that everyone wanting a regear nickels and dimes everything together over the course of a year or more, and just can't pony up the cash for a good deal Link to comment Share on other sites More sharing options...
Alexia Posted August 26, 2013 Share Posted August 26, 2013 If I could pick up a high pinion D30 already regeared with an aftermarket cover that had mileage on it I would pay around $400. For the D44, $600. Link to comment Share on other sites More sharing options...
SW86 Posted August 26, 2013 Share Posted August 26, 2013 . Link to comment Share on other sites More sharing options...
89MJMILSPEC Posted August 26, 2013 Share Posted August 26, 2013 Will I guess I could start the bidding out at $10.00. Link to comment Share on other sites More sharing options...
H3RESQ Posted August 26, 2013 Share Posted August 26, 2013 While I believe the 44/30 combo you have is worth $1200ish. I hate to say you probably will not get that for it. Simple fact is, if someone is keeping there 44/30 combo they are on a budget and probably can't pony up the $. If they do have the $ they will probably rather spend it upgrading the axles they have or building a 44 front. (especially considering how cheap you can get Rubi fronts for now) The rear 44 should be a easy sell, the front however is almost of no value since its a 30. Just is what it is. Rear..$500, front $300 (maybe $350-400 if you sleeved the axles and it has chromoly shafts, but you didn't mention those things) Link to comment Share on other sites More sharing options...
Blue XJ Posted August 27, 2013 Share Posted August 27, 2013 I just picked up a Dana 30 with 4.10's complete with brakes for $125. Unfortunately there isn't much value in a 30. Years ago I picked one up regeared to 4.56 with an ARB, warn hub conversion kit and warn chromolly shafts (about $4500 in parts) for $750 because he couldn't sell it for months. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted August 27, 2013 Share Posted August 27, 2013 4.10 should be cheaper since it was a common stock ratio Link to comment Share on other sites More sharing options...
lostissues Posted August 27, 2013 Author Share Posted August 27, 2013 so it looks like they are worth about what I have into them, and I will more then likely be getting offers for a bit less then that. Thanks for the input. Link to comment Share on other sites More sharing options...
92tanMJ Posted August 28, 2013 Share Posted August 28, 2013 Want to sell them to fellow Jeeper :brows: Lmao but since I just spent literally $584.32 on JUST my USED textbooks I'm not sure if I have the cash you want for them. But I would LOVE to pick those up from you. Link to comment Share on other sites More sharing options...
lostissues Posted September 2, 2013 Author Share Posted September 2, 2013 Unfortunately shipping would probably be quite a bit to Ohio, that and right now the axles are still under the truck. (also, buy your textbooks online if you don't already, campus bookstores are a ripoff.) Link to comment Share on other sites More sharing options...
92tanMJ Posted September 2, 2013 Share Posted September 2, 2013 Unfortunately shipping would probably be quite a bit to Ohio, that and right now the axles are still under the truck. (also, buy your textbooks online if you don't already, campus bookstores are a ripoff.) I'm actually like an hour north of nashville for school at WKU. And it would be a lot, but gas is cheaper and I have a pretty long winter break. hahah and the sad thing is I did. And I shopped around for the cheapest books. It's the 100 bucks per access code that gets ya. Flipping rip off. 100 bucks to let me join an online website. Link to comment Share on other sites More sharing options...
92tanMJ Posted September 15, 2013 Share Posted September 15, 2013 Hey Lost I sent you a PM Link to comment Share on other sites More sharing options...
