I recently did a bunch of brake work on my 91 MJ. I swapped in an MJ D44 with the larger drum brakes, removed the bed biasing device and ran a single line to the rear through an adjustable prop valve, and I just installed a 95 booster and master cylinder. When I went to bleed the front calipers I broke a bleed screw so I replaced the calipers and rotors. I bled the system quite well and there is a huge difference in braking, but when I first push in the pedal it does feel a bit spongy. Is this normal?
What brand of adjustable proportioning valve did you use?  Does it hold residual pressure to the drums?    Are the Cylinders in the drums good?   Did you use a new hose from bed to rear axle?   What about the the fronts?       I'm just proposing ideas, if you did the dual booster upgrade and kept your old rubber hoses maybe they're swelling some...
With the exception of the front brake lines, everything is new. The prop valve I used is identical to this: http://www.coloradomustang.com/ShowItem/100714%20Mustang%20Disc%20Brake%20Proportioning%20Valve%2064%20-%2073.aspx but I didn't think to put a check valve in when I installed it. I wound up making a pump brake bleeder this evening and re-bled the truck (yes, in the right order). Although the cap on the 95 booster leaked a bit of fluid I didn't see any bubbles at any of the wheels when I re-bled things. After the bleed the brakes are a bit more firm. Does the pressur holding vavle for the rear brakes make a big difference?
did you keep the stock proportioning valve then?   the one you sent a link to is just one line in one line out valve.       So if you kept the stock one and eliminated one line did you plug the correct port?
The residual pressure valves are often used in hot rod applications where the master is near level with the brakes, but a few people have used them, Not needed was just to see if it could have been a cause for your issue.
was the booster used?
sometimes it's the simple things, did you tighten all the bolts holding the booster to the truck well?   Was the firewall weak?
Do any of your bleeder valves leak?
Yep, kept the stock prop/combination valve. The adjustable one sits between the stock one and the new single rear line I ran, keeps the rear brakes from locking up. The correct port has been plugged. The booster and all the other parts I installed are brand new. Firewall's in good shape and all bolts have been tightened (and rechecked) to the specified torque in the Haynes manual. The bleeder valves don't leak. I've left the truck in the garage overnight and not a drop has shown up on the floor. I looked at all the fittings and they're bone dry.
After I did the re-bleed last night things are seeming a lot better even though I didn't see any air bubbles at all. I can feel the difference in braking power is way better than the stock system. I think it's fine now. I'm just a bit concerned as I'll have a camper on the truck and I'll be towing a fairly heavy load as well, which is what made me put the better braking system in the first place.
The MJ doesn't have a prop/combination valve up front in the stock configuration like the XJs do. It is simply a distribution block; no proportioning or brake biasing happens internally. If you had not installed the adjustable inline valve, full brake bias would be applied to the rear brakes since you bypassed the original load sensing proportioning valve. If plumbed and bled correctly, your setup is fine.
Apologies on the bad terminology. I realize the prop/combi device is just a distribution block. I just went with what everyone seems to call it. I read all the articles here on the brake work I did and I am quite happy with the results. The increase in braking power is quite noticeable. The "spongy" feeling at the start of pressing the brake pedal had me concerned. She stops like a champ though.
  • 3 weeks later...
