Cutting Down Drive Shaft Slip Yoke. Bad Idea?
With the addition of the 8.8 axle, my rear drive shaft will be 1" too long.
What do you think of if I just remove 1" off the end of the slip yoke? Seems like it would work out ok, but thought i'd ask...
contact from bottoming out doesn't just happen on the outside where you can see it.  It also happens on the inside. I don't know if there's enough room inside to do what you are looking to accomplish
a rear driveshaft out of a shortbed/4.0/automatic is 1 inch shorter. :thumbsup:
As much Slip that's there on the shaft I Doubt you'd need to trim it esp if you're adding any sort of lift.  I saw you're staying SUA, but didn't see if you were changing springs or not.
On another note post some pictures of your rig with the fender flares on.
Good to know info. Now that I have crawled under and looked, cutting the yoke down won't accomplish a thing since  it isn't bottoming inside the tail shaft, but at the yoke where the u-joint starts.
Post 102 and 107 has the pictures.
http://comancheclub.com/topic/37070-maura-gets-a-facelift-1990-4x4/page-6
To answer the thread, it's not a bad idea to cut down a slip yoke as long as it's internally fully splined. Some of them are not. I trimmed a long 27-spline GM yoke down after I did the original lift and ran it a few years until I was finished playing with the lift. Worked fine.
