Scott86mj Posted March 31, 2007 Share Posted March 31, 2007 I have a 94 xj 4.0l in my MJ. I just cranked it after setting in my garage most of the winter. It has a bad oil leak that looks to be coming from the Piece that the oil filter screws into. It has a big torxs screw on the end of it is there a gasket that I can replace or maybe it needs tightening? I don't have a torxs big enough to fit it so I didnt try that yet. Anybody have this leak before if so what was the fix. Thanks Link to comment Share on other sites More sharing options...
Mitch Posted March 31, 2007 Share Posted March 31, 2007 there was a write-up about that and how common of a problem as far as leaks go on the 4.0L.... I will poke around and see what I find, I know it was posted recently so maybe someone can point you to it. Link to comment Share on other sites More sharing options...
Eagle Posted April 1, 2007 Share Posted April 1, 2007 There's an O-ring kit you can get from any Mopar dealer to fix that. I think it consists of two O-rings. Not expensive. Link to comment Share on other sites More sharing options...
87MJJeep Posted October 5, 2007 Share Posted October 5, 2007 There's an O-ring kit you can get from any Mopar dealer to fix that. I think it consists of two O-rings. Not expensive. I think I have pinpointed my leak to that. Must the oil be drained to perform this repair or just remove the filter? Is there a torque spec on the bolt? Is thread locker recommended? I just changed my oil the week I got the truck less than a month ago. If I have to drain it, I'll just wait till the next oil change. How many here have rotated their adapter while changing the o-rings? Thanks! Link to comment Share on other sites More sharing options...
jtdesigns Posted October 5, 2007 Share Posted October 5, 2007 I have a 94 xj 4.0l in my MJ. I just cranked it after setting in my garage most of the winter. It has a bad oil leak that looks to be coming from the Piece that the oil filter screws into. It has a big torxs screw on the end of it is there a gasket that I can replace or maybe it needs tightening? I don't have a torxs big enough to fit it so I didnt try that yet. Anybody have this leak before if so what was the fix. Thanks An Allen wrench will turn a torex screw. Just don't over torque it. Link to comment Share on other sites More sharing options...
FxRacing282 Posted October 5, 2007 Share Posted October 5, 2007 I have a 94 xj 4.0l in my MJ. I just cranked it after setting in my garage most of the winter. It has a bad oil leak that looks to be coming from the Piece that the oil filter screws into. It has a big torxs screw on the end of it is there a gasket that I can replace or maybe it needs tightening? I don't have a torxs big enough to fit it so I didnt try that yet. Anybody have this leak before if so what was the fix. Thanks An Allen wrench will turn a torex screw. Just don't over torque it. do it right or don't do it! if you have to turn it go to sears and get the one you need :bowdown: sears Link to comment Share on other sites More sharing options...
jtdesigns Posted October 5, 2007 Share Posted October 5, 2007 I have a 94 xj 4.0l in my MJ. I just cranked it after setting in my garage most of the winter. It has a bad oil leak that looks to be coming from the Piece that the oil filter screws into. It has a big torxs screw on the end of it is there a gasket that I can replace or maybe it needs tightening? I don't have a torxs big enough to fit it so I didnt try that yet. Anybody have this leak before if so what was the fix. Thanks An Allen wrench will turn a torex screw. Just don't over torque it. do it right or don't do it! if you have to turn it go to sears and get the one you need :bowdown: sears I understand that, I was just pointing that out, it may help someone in a pinch. Sometimes you have to get something done without the time to run to sears, which by the way, I just returned from sears with a fuel pressure gauge. The only question I have is,- Is every product in America made in China?? :mad: It's hard to buy American when theres nothing made in America, but foreign cars!!! This country is falling apart; I'm buying more ammo! Link to comment Share on other sites More sharing options...
FxRacing282 Posted October 5, 2007 Share Posted October 5, 2007 haha man i love my guns... i think you can get wooden chairs that are made in america... but i think thats about it Link to comment Share on other sites More sharing options...
Renegade Posted October 6, 2007 Share Posted October 6, 2007 http://www.anvari.org/fun/Ethnic_Chines ... ation.html Link to comment Share on other sites More sharing options...
jtdesigns Posted October 6, 2007 Share Posted October 6, 2007 http://www.anvari.org/fun/Ethnic_Chinese/chinese_translation.html HAHAAAA Now thats funny! :cheers: Link to comment Share on other sites More sharing options...
Oizarod115 Posted October 6, 2007 Share Posted October 6, 2007 How many here have rotated their adapter while changing the o-rings? Thanks! good question.. that DARNED filter is the most annoying thing ever. dumps all over the place every oil change. is it possible to turn it so the filter is upside down? Link to comment Share on other sites More sharing options...
jtdesigns Posted October 6, 2007 Share Posted October 6, 2007 How many here have rotated their adapter while changing the o-rings? Thanks! good question.. that DARNED filter is the most annoying thing ever. dumps all over the place every oil change. is it possible to turn it so the filter is upside down? They make kits to relocate it don't they? could add a cooler too if your going to all that trouble.. Link to comment Share on other sites More sharing options...
