drase Posted April 23, 2013 Share Posted April 23, 2013 The piece of metal that the doorpin goes thru on the body that connects to the door (where my finger is pointing too). I need the passenger side one if it makes a difference shipped to 33884. Link to comment Share on other sites More sharing options...
sinkrun Posted April 23, 2013 Share Posted April 23, 2013 Door Check is what its called best to find a 97 up cherokee one there made better and a direct fit. Left or right does not matter however the one on the right side is less worn most of the time if you have a choice. Front and back are different will not interchange. Hope this helps some. Link to comment Share on other sites More sharing options...
drase Posted April 23, 2013 Author Share Posted April 23, 2013 Ok, thank you! Link to comment Share on other sites More sharing options...
MJRemi Posted April 23, 2013 Share Posted April 23, 2013 This is it but no pics: http://teamcherokee.com/door-check-pin-w-nuts-cherokee-1984-2001/ Sorry, I just re-read the ad and it's for the pin, not the check arm. Look through TeamCherokee, I was sure I'd seen the check arms on there. Link to comment Share on other sites More sharing options...
drase Posted April 23, 2013 Author Share Posted April 23, 2013 Found this but its for both and includes more than just the metal bar: http://teamcherokee.com/front-door-check-set-oem-cherokee-comanche-1984-2001/ And its way too expensive. Link to comment Share on other sites More sharing options...
BillyFryBMX Posted April 23, 2013 Share Posted April 23, 2013 I definitely have both somewhere. I'm pretty sure they're in my doors. I'll check for you when I get home and I'll let you know. Link to comment Share on other sites More sharing options...
sinkrun Posted April 23, 2013 Share Posted April 23, 2013 I will be at the yard wendesday if I have time I will grab a set even if you don't need them I should have a set in the shop. Link to comment Share on other sites More sharing options...
BillyFryBMX Posted April 23, 2013 Share Posted April 23, 2013 I wasn't able to find them. If I come across them I'll let you know if you still need it. Link to comment Share on other sites More sharing options...
drase Posted April 24, 2013 Author Share Posted April 24, 2013 I will be at the yard wendesday if I have time I will grab a set even if you don't need them I should have a set in the shop. Awesome, thanks buddy! Link to comment Share on other sites More sharing options...
drase Posted April 24, 2013 Author Share Posted April 24, 2013 I wasn't able to find them. If I come across them I'll let you know if you still need it. Thanks for looking! Link to comment Share on other sites More sharing options...
BillyFryBMX Posted April 24, 2013 Share Posted April 24, 2013 I wasn't able to find them. If I come across them I'll let you know if you still need it. Thanks for looking! No problem! Link to comment Share on other sites More sharing options...
sinkrun Posted May 7, 2013 Share Posted May 7, 2013 PM sent I found one. Link to comment Share on other sites More sharing options...
mjtjnj Posted May 8, 2013 Share Posted May 8, 2013 Don't wanna hijack drase but I could use these on both sides too. I have the jamb end and bolts. Need the part that goes inside the door, the rod, and pin. How do you get the roll pin back in after beating the hell out of it to get it off? Tom Link to comment Share on other sites More sharing options...
drase Posted May 10, 2013 Author Share Posted May 10, 2013 PM sent I found one. Responded! Link to comment Share on other sites More sharing options...
drase Posted May 10, 2013 Author Share Posted May 10, 2013 Don't wanna hijack drase but I could use these on both sides too. I have the jamb end and bolts. Need the part that goes inside the door, the rod, and pin. How do you get the roll pin back in after beating the hell out of it to get it off? Tom I haven't had to put the pin back in yet. I'll let ya know if I get the metal piece to put it in! Link to comment Share on other sites More sharing options...
drase Posted July 17, 2013 Author Share Posted July 17, 2013 Bump, still need this part shipped to 33884 Link to comment Share on other sites More sharing options...
jimoshel Posted July 18, 2013 Share Posted July 18, 2013 $8 shipped Link to comment Share on other sites More sharing options...
drase Posted July 19, 2013 Author Share Posted July 19, 2013 $8 shipped PM'd you Link to comment Share on other sites More sharing options...
