huck731 Posted April 21, 2013 Share Posted April 21, 2013 I want to lower the front of my mj by 1-2 inches, but outside of cutting the spring down I have no clue how to do so. Link to comment Share on other sites More sharing options...
Geonovast Posted April 21, 2013 Share Posted April 21, 2013 Coils off the rear of a ZJ will do exactly what you want. I seem to recal some trimming of the bumpstop is needed to get the coil over it. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted April 21, 2013 Share Posted April 21, 2013 rear coils from a ZJ will accomplish this, but you will want some good shocks to make the ride better. Lift blocks in the rear will drop it if you leave it SUA Link to comment Share on other sites More sharing options...
huck731 Posted April 21, 2013 Author Share Posted April 21, 2013 will I need different struts, or are the oe ones still going to be fine? Link to comment Share on other sites More sharing options...
huck731 Posted April 21, 2013 Author Share Posted April 21, 2013 I am actually planning on installing some rancho 5000 shocks with 2" lift in the rear Link to comment Share on other sites More sharing options...
JeepcoMJ Posted April 21, 2013 Share Posted April 21, 2013 then leave the front alone. and stock shocks would work, but you'd be best off getting some shorter if you were to drop it down. Link to comment Share on other sites More sharing options...
huck731 Posted April 21, 2013 Author Share Posted April 21, 2013 thanks for the info Link to comment Share on other sites More sharing options...
Darren Posted April 22, 2013 Share Posted April 22, 2013 A 2" drop is a lot on these trucks. A 2" drop from my 20 year old springs would have put my upper control arms into the oil pan and motor mount. If you look at my build thread (George) you'll see how much work I put into a ~3.5" drop upfront. These trucks come with tall motors, a compact engine bay, and a beam axle. That's not a good combination when in comes to lowering a vehicle. Link to comment Share on other sites More sharing options...
yellaheep Posted April 22, 2013 Share Posted April 22, 2013 Yep, definitely be sure to have SOLID bump stops that halt all up travel before the front axle beam hits the oil pan. These are MJ 4cyl front coils under a 6cyl engine. Rear used 2.5" or 3" blocks...... can't recall the size exactly. Link to comment Share on other sites More sharing options...
huck731 Posted April 22, 2013 Author Share Posted April 22, 2013 I don't want an even drop (yet), I'm going for a rake effect. so I'll just do the rear lift shocks for now, but as for the zj rear sprigns in front for that drop, while the v6 springs still lower the front end on a 2.5? yellaheep: what size tires are on the front of you mj, those look really skinny. Link to comment Share on other sites More sharing options...
92tanMJ Posted April 22, 2013 Share Posted April 22, 2013 Mine has that rake effect from the factory, I personally think its ugly and wish mine didnt have it Maybe instead of lowering it, you just need new rear leafs? Link to comment Share on other sites More sharing options...
dasbulliwagen Posted April 22, 2013 Share Posted April 22, 2013 You go for rake like youre wanting and your caster adjustment in the front end will be gone and youll be prone to death wobble. If you do this at least get the alignment and caster adjustment done professionally. Link to comment Share on other sites More sharing options...
huck731 Posted April 23, 2013 Author Share Posted April 23, 2013 I have the death wobble already comes and goes. this is going to be on the list of things that get done right before I get it aligned (fixing the death wobble is part of that.) thanks for the heads up on the on that though. Link to comment Share on other sites More sharing options...
yellaheep Posted April 23, 2013 Share Posted April 23, 2013 I don't want an even drop (yet), I'm going for a rake effect. so I'll just do the rear lift shocks for now, but as for the zj rear sprigns in front for that drop, while the v6 springs still lower the front end on a 2.5? yellaheep: what size tires are on the front of you mj, those look really skinny. No, the 2.8 V6 coils won't really net any drop given that the weight difference between the 2.8 and 4.0 isn't much. Front tires were a 26 or 27 x 4.5x15 .... Can't recall specifically. Link to comment Share on other sites More sharing options...
huck731 Posted April 23, 2013 Author Share Posted April 23, 2013 ok screw it, I'll just drop the whole thing. but still me having the 2.5, what coils will give me drop on the front? Link to comment Share on other sites More sharing options...
Geonovast Posted April 23, 2013 Share Posted April 23, 2013 ok screw it, I'll just drop the whole thing. but still me having the 2.5, what coils will give me drop on the front? Coils off the rear of a ZJ will do exactly what you want. I seem to recal some trimming of the bumpstop is needed to get the coil over it. Link to comment Share on other sites More sharing options...
huck731 Posted April 24, 2013 Author Share Posted April 24, 2013 ok, I guess I was just overthinking it in my head. the whole "these are coming off a zj which has more rear end weight and a v6, but if placed up front it will lower the front end?" Link to comment Share on other sites More sharing options...
Geonovast Posted April 24, 2013 Share Posted April 24, 2013 I don't think it's a question of weight, but more of length. Regardless of exact reason, though, Pat and I did put rear ZJ coils on the front of a 2.5 MJ and it dropped it an initial 1 1/2" and settled closer to 2". Just make sure you take care of the alignment just as you would after any lift. Link to comment Share on other sites More sharing options...
huck731 Posted April 25, 2013 Author Share Posted April 25, 2013 I didnt think about hwo the lenght's might differ... ya, when this is executed it will be going to get an alignment the same or the next day. Link to comment Share on other sites More sharing options...
Darren Posted April 25, 2013 Share Posted April 25, 2013 Just curious why are you against cutting the spring? I cut 1.5 rings from my 2wd coils, and from my seat the spring rate feels the same, maybe very slightly stiffer. I put a wet towel on the springs and used a cutoff wheel to cut them so I wouldn't transfer heat into the spring. Doing this allowed me to lower it gradually until I was happy with the height. It was also free, and I didn't have to source springs from another vehicle. Link to comment Share on other sites More sharing options...
huck731 Posted April 25, 2013 Author Share Posted April 25, 2013 I'm not so much against it, I just want to illiminate the chance of me cutting one off to much and then still having to find a new spring. Link to comment Share on other sites More sharing options...
92tanMJ Posted April 25, 2013 Share Posted April 25, 2013 Why not just cut off half a ring at a time then? Link to comment Share on other sites More sharing options...
