1988 Comanchee Shuts Off Immediately
Parked the truck this morning, went to crank it to move it just a fem minute's ago, It will crank up but shut's off immediately when releasing the Key.  If you hold the Key with the starter engaged it will stay running fine. I tried by passing the Ballest resistor on the driver side fender with no luck, Any idea's what could be wrong?
No the engine actually run's I know the starter is engaged, BUT the truck is actually running, and it will rev up, I just poped the supply line off, when you turn the key to the Run position you don't get anything. no fuel until you turn the truck over. also sometime's you can turn the Key over sometime's and it won't do anything. at all, also none of the gauge's work, fuel gauge has never worked, but the temp gauge is pinned at 260, oil pressure is pinned at 20 or so, and the battery gauge never moves.
This may sound like a stupid question, but where is the Ignition switch? it is dark out side and I am quiting for tonight, but i didnt see it on the bottom of the collum did i miss it? or is it located else were? I know on the ford i had to change the ignition switch on it was mounted to the bottom of the collum...
Oh and the rod being bent i think is unlikely, but possible, truck was laid on it's side Saturday in a mud pit, but after getting it back on all 4's it cranked up fine several time's, then several times sunday and 2 or 3 times this morning, but i was using it to take trash to the back of the feild to be burnt since it is muddy back there and went to move it from my front step's and it at first wouldnt do anything like the battery was dead, then evetually i got it to turn over, and about every other time i tried to crank it it wouldnt do anything, but wiggling the key sometimes got it to turn over
Last time i bought one of those book's it was a waste of 20 buck's Ill never do that again, and yes it is a Auto, but i had a 97 that the NSS went out on and it wouldnt turn over at all, this one does turn over sometime's
Okay, I took a Ignition switch off a 87 Jeep i have (engine locked up about 5 months back) put it on this the comanche, same issue.
and It won't turn over everytime that you go to crank it over now, so i manually worked it with a screw driver and it still doesnt turn over but maybe once outta 10-15 times of turning it over, which makes me wonder if it is the NSS now...
i had this issue with my 96 but thats to late of a model to matter here and i actually lost power to one of the feed wires on the ignition switch it would run just fine with it turned to start but as soon as i would let off the key every thing would lose power
No gauges, fuel pump not priming, turning over intermittently and all of it in a very brief period of time. Sounds to me like a faulty battery ground. How old is the cable? When was the last time you refreshed the terminal clamps and cleaned the studs? You would not believe the kind of havoc a slightly loose or corroded battery terminal can cause.
When you have questions like this, you need a simple reference with pictures and step by step instructions..  Thats what I was referring too.  More power to ya using other methods..
battery terminal looks alright. it is tight. ill check the other end tonight. I'm not sure how old the ground from the battery is thou.
