ncwhiteguy Posted March 2, 2013 Share Posted March 2, 2013 Hey fellas just picked up my first Mj and already stoked! It is a blast to drive trying to figure out a few things that are different than what I'm used to (basically Wranglers ) also been restoring a wagoneer(that the wife hates) Here are the pics What is this lever on the axle? Link to comment Share on other sites More sharing options...
jimoshel Posted March 2, 2013 Share Posted March 2, 2013 That's the factory installed lift kit. You pump it until you get the lift you want. It's also known as a brake equalizer. Proportions the rear brakes to allow for the difference between a full and empty bed. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted March 2, 2013 Share Posted March 2, 2013 Nice truck. Looks like you have a good start. The thing on the rear axle is the rear brake proportioning valve, that adds braking power to the rear when there is more weight back there, and your is installed incorrectly, thus making you have almost no rear braking power. The rod needs to be straight up and down, and the lever needs to be about parralell to the ground going the other way. There are write ups on this site to remove this thing if you want to, or you could just unhook the rod and hook it back up correctly. Looks like you have the coveted rear dana 44 axle too. Nice score! And I assume youre in North Carolina.... where are you? Link to comment Share on other sites More sharing options...
ncwhiteguy Posted March 2, 2013 Author Share Posted March 2, 2013 Hickory, NC, and thanks for the info title says it was a pioneer edition going to get that fixed, truck is clean and runs great. It has been switched to a 5 speed instead of automatic Link to comment Share on other sites More sharing options...
Pete M Posted March 2, 2013 Share Posted March 2, 2013 That's the factory installed lift kit. You pump it until you get the lift you want. It's also known as a brake equalizer. Proportions the rear brakes to allow for the difference between a full and empty bed. Yup, it's the brake weight-sensing proportion valve. problem is that it's supposed to be pointing the other way. The big lever should be roughly parallel to the ground. :thumbsup: and welcome to the club! :waving: Link to comment Share on other sites More sharing options...
Exgrayxj Posted March 2, 2013 Share Posted March 2, 2013 HAH! That xj Waggy is the twin in color to the one I have! Mine is from Tenn, and has a LT1/700r4/4wd. And my MJ is a white swb/4wd/Sport. That pic could have been taken in my drive! Caution, mj's are addictive. Link to comment Share on other sites More sharing options...
MtnClimber Posted March 3, 2013 Share Posted March 3, 2013 What size tires and lift? Link to comment Share on other sites More sharing options...
ncwhiteguy Posted March 3, 2013 Author Share Posted March 3, 2013 I don't know that it has a lift our not the PO said he didn't think so either but its running 31x10.50, I think they will rub if I go off of the pavement Link to comment Share on other sites More sharing options...
87jeepmj Posted March 4, 2013 Share Posted March 4, 2013 Link to comment Share on other sites More sharing options...
ComancheKid45 Posted March 5, 2013 Share Posted March 5, 2013 Nice Truck! Make yourself at home, youll likely be here alot! :cheers: Link to comment Share on other sites More sharing options...
ncwhiteguy Posted March 8, 2013 Author Share Posted March 8, 2013 Whelp got to put the comanche to the test tonight lil'neighborhood kid got stuck in his xterra. Man I love pulling foreign pos out! Pics tomorrow, Link to comment Share on other sites More sharing options...
jeepsouth Posted March 8, 2013 Share Posted March 8, 2013 Ha ha ha! Nice! Link to comment Share on other sites More sharing options...
