Steering Options For 6.5 In Lift In Mj
What are you guys running for a steering set up with long arms and 6 in of lift? I just installed a rough country long arm upgrade with 6.5 in springs and bilstein 5100 shocks on my 86 lwb 4x4 MJ. At full droop my drag link at the knuckle is binding badly. What are my options without going to a over the knuckle steering setup or a inverted t setup? I'd like to keep the y link steering as it works properly with my new drop pitman and drop adjustable track bar. Thanks for any info.
Earl
I will give my experience with my MJ at 6.5 lift , I have fooled around with the steering for couple years and used different setups and drop pit arm ect.... for me only setup that met all my expectations and works perfect is using a JB conversions high steer adapter, RR steering system factory pit. problems solved.been a solid setup for several years now. but you can try the other stuff out there it may satisfy you? at 6" lift the steering needs to be changed to a high steer setup for best performance.
The systems below seem to be popular
JCRoffroad one ton steering
Rustys off road steering
Currie steering system
also Iron Rock Offroad
Comanchedude, do you run into bump steer now that you raised your drag link to the top of the knuckle or did you raise the axle end of the track bar?
Yes you do need to raise the track bar.. Of course I don't have any steering issues..it perfect. I really do me perfect nice tight exact ..just how you want the steering to be. I recommend to anyone with similar lift on MJ or xj to run this type steering setup..it's the deal. you can see the setup fairly well in this pic [imghttp://pic100.picturetrail.com/VOL1163/4194354/24293153/405425830.jpg[/img]
I've ran inverted t, crossover, and y-link. I've also ran tie tod ends and Heim joints.
If you ever drive your Jeep on the road I'd recommend the Currie Correctlync setup. It's worth the money.
If its Offroad only, I'd go crossover with WJ knuckles, and use heim joints.
