TGTgoHARD Posted February 17, 2013 Share Posted February 17, 2013 VIN# 1Jthl6578Gt079881 Link to comment Share on other sites More sharing options...
dasbulliwagen Posted February 18, 2013 Share Posted February 18, 2013 I ran your VIN through Chrysler, came back as VIN not found. 86 is too early to be in their system. Sorry. Link to comment Share on other sites More sharing options...
shelbyluvv Posted February 18, 2013 Share Posted February 18, 2013 I found a date code behind my door panels. Might be worth a look. Link to comment Share on other sites More sharing options...
89eliminator Posted February 18, 2013 Share Posted February 18, 2013 all my build dates ( and every other comanche i have seen) have been on the drive side door. the only problem is when someone swaps out doors... Link to comment Share on other sites More sharing options...
Alexia Posted February 18, 2013 Share Posted February 18, 2013 The frame/body build date can also be found stamped in the left wheel well on the frame near the brake line. I believe it shows up on the right side too. This build date should be within a few days of the final build date. Link to comment Share on other sites More sharing options...
TGTgoHARD Posted February 18, 2013 Author Share Posted February 18, 2013 The build date inside my truck door is rubbed off. I can see where it would be but its gone. Ill check the fender tomorrow when its light. Inside my door panel it says september 1985, but assume thats a date for when the door panel was built, not my truck? Link to comment Share on other sites More sharing options...
TGTgoHARD Posted February 18, 2013 Author Share Posted February 18, 2013 next to the brake line it says 108281 Link to comment Share on other sites More sharing options...
87MJTIM Posted February 18, 2013 Share Posted February 18, 2013 next to the brake line it says 108281 If you put that number in excel and convert to a date, you get June 16, 2196. I don't think that was it. :shake: Link to comment Share on other sites More sharing options...
MJ Journey Posted February 28, 2013 Share Posted February 28, 2013 I found the original factory build sheets behind the driver's door panel. I had to take it off so I could change the window crank assembly. It had specs on things from the radio to carpet to engine stuff. Build date was right there. I took it to my Jeep dealer and he was kind enough to "decipher" it for me. Link to comment Share on other sites More sharing options...
deziped Posted March 1, 2013 Share Posted March 1, 2013 Build sheets on my 88 & 89 were stuck under the seat between foam & springs. Link to comment Share on other sites More sharing options...
TGTgoHARD Posted March 2, 2013 Author Share Posted March 2, 2013 Build sheets on my 88 & 89 were stuck under the seat between foam & springs. Can anyone else confirm this? Link to comment Share on other sites More sharing options...
deziped Posted March 2, 2013 Share Posted March 2, 2013 Build sheets on my 88 & 89 were stuck under the seat between foam & spring They were both bench seats. Link to comment Share on other sites More sharing options...
87sparTruck Posted March 4, 2013 Share Posted March 4, 2013 The 89 parts truck I picked up had it taped to the driver's side floor board. Link to comment Share on other sites More sharing options...
flint54 Posted March 5, 2013 Share Posted March 5, 2013 My build sheet was found beneath the carpet on the passenger side. My truck also has a stamped metal dataplate riveted to the crossmember directly beneath the radiator. Link to comment Share on other sites More sharing options...
