JohnQ Posted March 12, 2007 Share Posted March 12, 2007 How hard would it be to wire up an electric cooling fan? I have been considering one of the new electric fans from ebay. Link to comment Share on other sites More sharing options...
Pete M Posted March 12, 2007 Share Posted March 12, 2007 It's simple, wire it in through a relay and to a switch on the dash. :D Turn it on whenever you want. If you're worried you might forget to turn it off, wire it in to a switched power source so it turns off with the truck. Simple. :D Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted March 12, 2007 Share Posted March 12, 2007 EASY!!!! I stole one form one of the XJ's I chopped up!! NICE mod for those HOT summer trail rides!!! Ran mine thru the fact thurmostat as wall as a switch to turn it on as required. CW Link to comment Share on other sites More sharing options...
whatis42 Posted March 12, 2007 Share Posted March 12, 2007 mine came with one I probably should see how it's wired up huh? ;) Why have an on demand switch at all if you have it wired to the thermostat? Link to comment Share on other sites More sharing options...
87manche Posted March 12, 2007 Share Posted March 12, 2007 mine came with one I probably should see how it's wired up huh? ;) Why have an on demand switch at all if you have it wired to the thermostat? because it's sometimes nice to turn it on so it runs all the time, it not only cools the motor, but the transmissions coolin section is right there as well. and if you've installed a power steering pump cooler it's likely right in front of the electric guy as well. Mine is straight afternarket, a HD hayden unit, it flows way more air than the sotck one, and it's wired to a switch. Didn't even bother with the fact stuff, as it never had one before. Link to comment Share on other sites More sharing options...
JohnQ Posted March 23, 2007 Author Share Posted March 23, 2007 Anyone have a used one in good working condition they want to part with? :D Link to comment Share on other sites More sharing options...
JeepcoMJ Posted March 23, 2007 Share Posted March 23, 2007 the new one is only 60 bucks....not too shabby. they're worth it and that specific one is GREAT!! Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 24, 2007 Share Posted March 24, 2007 How hard would it be to wire up an electric cooling fan? I have been considering one of the new electric fans from ebay. Am I missing something on JohnQ's original post? I thought all MJ's had an electric fans & a mech. fan regardless of years or engines. But all I've owned were HO models. But I have replaced all the slab straight bladed fans with the 1996+ XJ curved blade fans; they are quieter and seem to pass more air. Link to comment Share on other sites More sharing options...
Oizarod115 Posted March 24, 2007 Share Posted March 24, 2007 How hard would it be to wire up an electric cooling fan? I have been considering one of the new electric fans from ebay. Am I missing something on JohnQ's original post? I thought all MJ's had an electric fans & a mech. fan regardless of years or engines. But all I've owned were HO models. But I have replaced all the slab straight bladed fans with the 1996+ XJ curved blade fans; they are quieter and seem to pass more air. not some models, i think it came with ones that had a.c? correct me if I'm wrong, my 89 w AC has it, bros 90 w/ ac has it, moms 95 w ac has it. go-jeep did a writeup on replacing the clutch fan with an electric one. Link to comment Share on other sites More sharing options...
JohnQ Posted May 12, 2007 Author Share Posted May 12, 2007 EASY!!!! I stole one form one of the XJ's I chopped up!! NICE mod for those HOT summer trail rides!!! Ran mine thru the fact thurmostat as wall as a switch to turn it on as required. CW How do you tie it into the factory thermostat? Do you have a picture where the wires connect? Link to comment Share on other sites More sharing options...
87manche Posted May 12, 2007 Share Posted May 12, 2007 How hard would it be to wire up an electric cooling fan? I have been considering one of the new electric fans from ebay. Am I missing something on JohnQ's original post? I thought all MJ's had an electric fans & a mech. fan regardless of years or engines. But all I've owned were HO models. But I have replaced all the slab straight bladed fans with the 1996+ XJ curved blade fans; they are quieter and seem to pass more air. if you have a manual trans and no AC you didn't get one from the factory. Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 14, 2007 Share Posted May 14, 2007 Anyone have a used one in good working condition they want to part with? John; Have a good used one (OEM, not aftermarket) from a 1998 (has the curved blades) I'm willing to part with cheap. Shoot me a PM if interested. Looks like this - direct bolt-in replacement for the older straight blade style. Don Link to comment Share on other sites More sharing options...
JohnQ Posted May 14, 2007 Author Share Posted May 14, 2007 Anyone have a used one in good working condition they want to part with? John; Have a good used one (OEM, not aftermarket) from a 1998 (has the curved blades) I'm willing to part with cheap. Shoot me a PM if interested. Looks like this - direct bolt-in replacement for the older straight blade style. Don Thanks but I just bought one from rejeep and got it last Friday. I'm still trying to fiqure out how to wire it up if anyone has any pointers. Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 14, 2007 Share Posted May 14, 2007 Thanks but I just bought one from rejeep and got it last Friday. That's good John, but I could have beaten Arie's price. ;) And he's a good honest guy :cheers: Link to comment Share on other sites More sharing options...
Eagle Posted May 14, 2007 Share Posted May 14, 2007 How do you tie it into the factory thermostat? Do you have a picture where the wires connect? What year is your truck? On the Renix, there is NO connection to the factory thermostat. The aux fan is controlled by a sensor that screws into the bung in the driver's side radiator tank. The sensor is basically an ON-OFF switch, which in turn connects to the control side of a standard relay that's mounted to the inside of the driver's side fender. With the 91+ Chryco system, the aux fan is controlled by the ECM. You'll need a factory wiring diagram to figure out where to tap into the wiring harness to access that circuit. Link to comment Share on other sites More sharing options...
comanche-man22 Posted May 15, 2007 Share Posted May 15, 2007 one of the first things that i did was put in dual fans one turns on automatically and the other is manual with a switch on the dash. Link to comment Share on other sites More sharing options...
JohnQ Posted May 15, 2007 Author Share Posted May 15, 2007 How do you tie it into the factory thermostat? Do you have a picture where the wires connect? What year is your truck? On the Renix, there is NO connection to the factory thermostat. The aux fan is controlled by a sensor that screws into the bung in the driver's side radiator tank. The sensor is basically an ON-OFF switch, which in turn connects to the control side of a standard relay that's mounted to the inside of the driver's side fender. With the 91+ Chryco system, the aux fan is controlled by the ECM. You'll need a factory wiring diagram to figure out where to tap into the wiring harness to access that circuit. My truck is an 88. I was hoping there was a harness I could get so I could just plug and play. What gauge wire should I be using to hook up the fan? Link to comment Share on other sites More sharing options...
Wildman Posted May 15, 2007 Share Posted May 15, 2007 You could just add the switch in the raditor, wire it thru a relay, and have the set up automatic. Eagle explained it for you. The "switch" you need is here - About $18 http://www.partsamerica.com/ProductDeta ... 89&PTSet=A And the relay is here - $10 http://www.partsamerica.com/ProductDeta ... 99&PTSet=A Or set it up thru the relay and a manual switch like others do. Also, I got two '89's w/4.0, BA10 and both have the aux fans, must have been '89 and after all MJ's came with the aux fan. Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted May 15, 2007 Share Posted May 15, 2007 John, Sorry I missed this. I wired mine thru that thurmostatic switch in the rad just like factory. Than I ran a power wire and switch wire, everything thru a relay. Mine will come on as required OR when I throw the switch. I don't have the skematic infront of me and cannot remember for sure...but I think the the rad thurmo switch is not grounded. So I ran my switched wire thru it and back to power. When its too hot (Or reaches what the factory wanted the fan to come on) it allows the connection to be made, turning it on. Then I ran another wire, from the same switched pole, into the cab and thru a switch and back to 12V. That way I am able to turn it on as I want OR auto as required. At least I THINK thats how I did it. its all dependent on what or how that factroy thurmostatic switch worked. CW Link to comment Share on other sites More sharing options...
JohnQ Posted May 16, 2007 Author Share Posted May 16, 2007 Where did everyone mount their relays? Link to comment Share on other sites More sharing options...
ORCA Posted May 16, 2007 Share Posted May 16, 2007 Where did everyone mount their relays? High up in the engine compartment - away from potential water hazards. Also you must keep in mind the 4 wires coming out of it. I usually route my wires first then hard mount the relay. Link to comment Share on other sites More sharing options...
Pete M Posted May 17, 2007 Share Posted May 17, 2007 In the tupperware. :D Link to comment Share on other sites More sharing options...
JeepcoMJ Posted May 17, 2007 Share Posted May 17, 2007 In the tupperware. :D wow pete, wow Link to comment Share on other sites More sharing options...
Pete M Posted May 17, 2007 Share Posted May 17, 2007 I've got more. :D They're water resistant and heat tolerant. Oh, and cheap. Link to comment Share on other sites More sharing options...
ChiefJosh Posted May 17, 2007 Share Posted May 17, 2007 I've got more. :D They're water resistant and heat tolerant. Oh, and cheap. Pete that is amazing! So, uh, what brand do you prefer?....... That is, by the way, a fantastic idea. :cheers: Link to comment Share on other sites More sharing options...
