CRM1988 Posted December 30, 2012 Share Posted December 30, 2012 Can't get backup lights to work. Bulbs good, fuses good, any ideas? Link to comment Share on other sites More sharing options...
Keyav8r Posted December 30, 2012 Share Posted December 30, 2012 Switch not making contact? Do you have power at fuse? Trace wiring from back-up lights back to switch and check for continuity and check for power on fuse side of switch. If power at fuse and no power at switch, trace wiring between switch and fuse for continuity. Link to comment Share on other sites More sharing options...
cruiser54 Posted December 30, 2012 Share Posted December 30, 2012 Which Jeep? If it's the 90, I would suspect the NSS. If the 88, I would suspect the reverse light switch on the trans. But wait!! Just thought of this. Only on my 2nd cup of coffee. The 7.5 amp "trans" fuse in the fusebox has to be good in order for the reverse lights to work. Link to comment Share on other sites More sharing options...
vaquaro Posted December 30, 2012 Share Posted December 30, 2012 :agree: Somewhat confusing ( versus "B/U" lamp fuse ) but true Link to comment Share on other sites More sharing options...
wdpk Posted December 30, 2012 Share Posted December 30, 2012 I was having this problem with my 86, swapped out the Back Up Switch in the transmission with one from a junkyard, and lights work. Parts stores wanted $55 for it though, at that price, I'd just wire up a manual one! Link to comment Share on other sites More sharing options...
jimoshel Posted December 31, 2012 Share Posted December 31, 2012 Just leans out the window holding a flashlight. Link to comment Share on other sites More sharing options...
Pete M Posted December 31, 2012 Share Posted December 31, 2012 also could be corrosion in the wire harness connector just behind the rear drivers side tire. :thumbsup: Link to comment Share on other sites More sharing options...
cruiser54 Posted January 1, 2013 Share Posted January 1, 2013 Check the "trans" fuse first............ Link to comment Share on other sites More sharing options...
