SR44 Posted December 7, 2012 Share Posted December 7, 2012 I just bought an 88 Comanche and it has a posi rear end, was that an option? Link to comment Share on other sites More sharing options...
Eagle Posted December 7, 2012 Share Posted December 7, 2012 Yes, and no. A limited slip differential was a factory option, but Jeep called it Trac-Lok. "Posi" is short for "Positraction," and that name belongs to Generous Motors. Link to comment Share on other sites More sharing options...
airspeed Posted December 7, 2012 Share Posted December 7, 2012 Is it the Dana 44?, or it has been upgraded. I think the 1 ton came with Dana 44 w/limited slip, not sure. The older posi's can be a bit of a problem with the clutch packs in there, you get a poping sound when making a tight turn... Link to comment Share on other sites More sharing options...
Pete M Posted December 7, 2012 Share Posted December 7, 2012 the limited slip was still an option, even with the big ton package. Link to comment Share on other sites More sharing options...
cruiser54 Posted December 7, 2012 Share Posted December 7, 2012 Is it the Dana 44?, or it has been upgraded. I think the 1 ton came with Dana 44 w/limited slip, not sure. The older posi's can be a bit of a problem with the clutch packs in there, you get a poping sound when making a tight turn... My Pioneer has a 44 with limited slip. Link to comment Share on other sites More sharing options...
Eagle Posted December 8, 2012 Share Posted December 8, 2012 Is it the Dana 44?, or it has been upgraded. I think the 1 ton came with Dana 44 w/limited slip, not sure. The older posi's can be a bit of a problem with the clutch packs in there, you get a poping sound when making a tight turn... If you're getting any "ratcheting" on turns, it means you need to add friction modifier to the gear lube. That's not really a "problem" in my book, because it proves that the limited slip clutches aren't worn out and that they still have some grab left in them. Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 8, 2012 Share Posted December 8, 2012 Is it the Dana 44?, or it has been upgraded. I think the 1 ton came with Dana 44 w/limited slip, not sure. The older posi's can be a bit of a problem with the clutch packs in there, you get a poping sound when making a tight turn... I've heard this a lot. I don't get any popping sound making tight turns. I've tried to make the popping sounds with it. My D44 has new gears, new clutch packs with correct diff fluid and additive. :hmm: Link to comment Share on other sites More sharing options...
MJRemi Posted December 8, 2012 Share Posted December 8, 2012 I'm about to refill the AMC 20. What additive is recommended and for what purpose? Link to comment Share on other sites More sharing options...
airspeed Posted December 8, 2012 Share Posted December 8, 2012 I put Lucas 75W-90 synthetic gear oil in mine, no additive. My Dana 44 w/ limited slip is smooth and quiet. Link to comment Share on other sites More sharing options...
