Wrz Posted April 2, 2013 Author Share Posted April 2, 2013 Slowly getting closer to getting the engine and trans in Made some progress in the engine compartment and interior Pulled my dash since it was all cracked and decided to change the heater core Alot of good write ups out there Need to find the after pics still Upgraded the booter to one from a 99 xj New on the left and old one on the right New sensor And a few pictures of the booster installed, painted washer bottle, and some of the wiring buttoned up My goal is to have the drive train all bolted in Still waiting for my motor mounts, need trans bolts, And a few ther misc items for the engine and trans stay tuned Prevous total- $2387.23 Heater Core $30 Fuel pump resistor - $19.44 Cost to date- $2426.67 Link to comment Share on other sites More sharing options...
ComancheKid45 Posted April 2, 2013 Share Posted April 2, 2013 Very Nice! can't wait to see it come together! Link to comment Share on other sites More sharing options...
earl*t Posted April 3, 2013 Share Posted April 3, 2013 I'm liken your style Mr. Wrz. Link to comment Share on other sites More sharing options...
Wrz Posted April 3, 2013 Author Share Posted April 3, 2013 Thanks for all the comments guys, should be making some good progress within the next two weeks Link to comment Share on other sites More sharing options...
Wrz Posted April 5, 2013 Author Share Posted April 5, 2013 Started working on my driveshafts tonight, Got all the u joints pulled, and all i needed was 2 4x4's a hammer, screw driver and a socket :D Here are a few pictures, should have cleaned painted and the new joints installed shortly Starting to get there lol Link to comment Share on other sites More sharing options...
Wrz Posted April 9, 2013 Author Share Posted April 9, 2013 Well i did not reach my goal this past weekend, Still need to get some trans bolts, and my current dd xj blew a front diff so i was swapping that all weekend Did manage to clean/paint and install my drive shaft joints Here are a few pictures Fresh coat of paint The goodies, I went with spicer 5-785x the non greaseable one Needed a total of 5 to get the job done Some pics of the finished product Prevous total - $2426.67 5 spicer u joints Ebay special - $72.00 Cost to date - $2498.67 Started to paint my interior trim with some sem....Amazing product and will post pictures soon Link to comment Share on other sites More sharing options...
Scottracer Posted April 9, 2013 Share Posted April 9, 2013 Looking great!! What did you do to clean up drive shafts? And what paint did you use? I am currently replacing Slave cylinder and have mine out and want to do the same. Thanks Link to comment Share on other sites More sharing options...
Wrz Posted April 9, 2013 Author Share Posted April 9, 2013 Looking great!! What did you do to clean up drive shafts? And what paint did you use? I am currently replacing Slave cylinder and have mine out and want to do the same. Thanks Hey I used a brillow pad and some sand paper so scuff them down, rubbing alcohol to clean them off. I had some extra high heat temperature paint Laying around I used I also did to coats Thanks Link to comment Share on other sites More sharing options...
Wrz Posted April 14, 2013 Author Share Posted April 14, 2013 Empty Post Link to comment Share on other sites More sharing options...
Wrz Posted April 22, 2013 Author Share Posted April 22, 2013 Empty Post Link to comment Share on other sites More sharing options...
Wrz Posted April 29, 2013 Author Share Posted April 29, 2013 Empty Post Link to comment Share on other sites More sharing options...
Wrz Posted April 29, 2013 Author Share Posted April 29, 2013 Man anyone know why photobucket keeps turning my pictures? Their at the correct angle when i upload them and copy the code, but turn when i upload the links on here they are sideways :hmm: Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted April 29, 2013 Share Posted April 29, 2013 What fuel issues are you having? Link to comment Share on other sites More sharing options...
Wrz Posted April 29, 2013 Author Share Posted April 29, 2013 What fuel issues are you having? Haven't really had a chance to diagnose the problem, when I had everything all hooked up the pump was not kicking on and had no pressure at the fuel rail, Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted April 30, 2013 Share Posted April 30, 2013 Haven't really had a chance to diagnose the problem, when I had everything all hooked up the pump was not kicking on and had no pressure at the fuel rail, Check Ground, then look for 12v at the fuel pump plug. Fuel pump ground can be found behind the rear driver side tail light, common problem spot. Also if you are not getting 12v to the pump check/replace/bypass the fuel pump ballast resistor. Link to comment Share on other sites More sharing options...
Wrz Posted April 30, 2013 Author Share Posted April 30, 2013 Haven't really had a chance to diagnose the problem, when I had everything all hooked up the pump was not kicking on and had no pressure at the fuel rail, Check Ground, then look for 12v at the fuel pump plug. Fuel pump ground can be found behind the rear driver side tail light, common problem spot. Also if you are not getting 12v to the pump check/replace/bypass the fuel pump ballast resistor. Think you solved my problem since I have no bed on currently , will see if it kicks on with a ground on the frame Link to comment Share on other sites More sharing options...
Wrz Posted May 4, 2013 Author Share Posted May 4, 2013 Minor progress made, Finally the nice weatherr comes, and so are all the b-days and family functions so the comanche keeps getting pushed off Finally recieved my transmission line adapter New transmission lines Installed on the transmission Installed on radiator New ac condensor ( just for looks until i can find some replacement lines ) Half way installed ( when i did the open cooling upgrade my radiator won't line up with the upper support Prevous total - $2977.85 Transmission adapters-$18.12 Trans line- $55 total for the 3 Condensor-$69.69 Cost to date - $3120.66 Lets see if i can keep the finished product under 5k.... and bets :group beer: Link to comment Share on other sites More sharing options...
Wrz Posted May 7, 2013 Author Share Posted May 7, 2013 Slight update, finished up the upper rad support, installed a refurbished battery, tossed the fenders on ( not lined up yet) and pulled and installed my tunnel plate Here are a few pictures, sorry quality is not the best, the sun was beaming right onto the manche Tunnel plate installed an modified 5.9 zj shifter mocked up Pass Fender Upper rad Drivers side fender And an overall shot Starting to look like a jeep but man i still have a ways to go, my goal is to have it done buy the end of june Prevous total - $3120.66 Tunnel Plate- Work Perk 5.9 Shifter- Left over part out Both Fenders- $216.61 Refurbished Battery- $35 Cost to date - $3372.27 Link to comment Share on other sites More sharing options...
Wrz Posted May 12, 2013 Author Share Posted May 12, 2013 Finally found a coolant bottle that works, somewhat, had to heat it up with a heatgun to mold it some and fixed my po's splices and wired in my h4 headlight harness Before and after H4 harness relays mounted Coolant bottle installed Prevous total - $3372.27 Coolant Bottle-$14.99 Advanced auto Putco 230004HW- $40.60 Cost to date - $3427.86 Link to comment Share on other sites More sharing options...
Wrz Posted May 16, 2013 Author Share Posted May 16, 2013 Little more progress today and should have most of the dash all finished up by this weekend Sorry i didnt take any before pictures Dash has a few cracks and a hole on the drivers side, patched with some jb weld Wasnt major, but figured while i had the jb weld out to touch it up Painted the whole dash with black SEM Finished and painted patch Before And after ( Finally cleaner looking and looks more put together ) Will update again tomorrow :) Have all the trim and interior plastics painted, but need to dye my seatbelts Link to comment Share on other sites More sharing options...
Wrz Posted May 21, 2013 Author Share Posted May 21, 2013 Empty Post Link to comment Share on other sites More sharing options...
dlee Posted May 22, 2013 Share Posted May 22, 2013 Looking good! And what a steal on that XJ!!! Where did you find your trans lines? Link to comment Share on other sites More sharing options...
Wrz Posted May 22, 2013 Author Share Posted May 22, 2013 Looking good! And what a steal on that XJ!!! Where did you find your trans lines? They have them at advanced auto, but i found them all on ebay cheaper, if you want i can pm you the links Link to comment Share on other sites More sharing options...
Wrz Posted May 25, 2013 Author Share Posted May 25, 2013 Empty Post Link to comment Share on other sites More sharing options...
Wrz Posted May 26, 2013 Author Share Posted May 26, 2013 Empty Post Link to comment Share on other sites More sharing options...
