snakedoc67 Posted October 28, 2012 Share Posted October 28, 2012 local parts and pull has an 88 manche with good cab corners and rocker panels. I was wondering if theres a way to remove the entire cab from the frame as they won't sell the entire vehicle? Link to comment Share on other sites More sharing options...
Geonovast Posted October 28, 2012 Share Posted October 28, 2012 Nope. Bed comes off the frame normally, but the frame and cab are unibody. Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted October 28, 2012 Share Posted October 28, 2012 It is, with enough time, oxy acetylene, and spot weld cutters its possible. But its just not practical, if the rockers and cab corners are what you need you are better off hacking them off and using them to replace yours. The cab of a comanche uses a type of cab design called unibody in other words the cab is literally part of the frame, and vice-a-versa. Making it non removeable. . . technically. It make for an extremely rigid and strong vehicle body, but it does have its drawbacks. Link to comment Share on other sites More sharing options...
Minuit Posted October 28, 2012 Share Posted October 28, 2012 The other guys have it. The cab and frame are permanently connected. It's supposed to make the frame strong (and an MJ unibody is rather strong) but it's a pain sometimes. I would just cut off the parts I needed and welded them to my truck. Link to comment Share on other sites More sharing options...
Keyav8r Posted October 29, 2012 Share Posted October 29, 2012 If you plan to cut them out with a rechargeable sawzall, take about six fully charged batteries with you and that may be enough. It took two batteries to cut out the rear fender wheel well areas (above and behind the flares). Also, get the shortest, stiffest blades you can find and take a bunch of them. And, don't buy the cheap ones, they don't last. The long blades tend to flex and bend - don't ask how I know that. Link to comment Share on other sites More sharing options...
jimoshel Posted October 29, 2012 Share Posted October 29, 2012 Not sure what kind of SAWZALL Keyav8r has. I cut up a 14X60 mobile home frame, 14 inch I beam making 10 cuts with a Makita Sawzall on one charge. He's right on about the blades tho. Link to comment Share on other sites More sharing options...
