Fuel Line; Rubber Pressure Line
I was tinkering with the 90 eliminator and decided I was going to fire it up and start down the path of putting it back on the road. When I fired it this odd smoke was coming off the exhaust manifold. I figured just oil from a leaky valve cover,.. But it continued and smelled quite odd.
Then I realized the pressure line was sending a nice supply of fuel down to the toasty manifold.
That's baaaaad!!! I shut it off RFN!!!!
Looked on line for a replacement but haven't been able to locate the part number or stock.
Help?!?!??!!!??
  • 1 month later...
Shouldn't be that hard to get the parts and fabricate one. just make sure you use a hose for high pressure and not regular hose.
But how would i make a high pressure fitting? I realize i can fabricate the steel part but wht about the transition to the rubber hose? I would rather just buy one do to lack of time, but I'm not totally opposed to making something.
