Radio Control (Rc) Comanche
Butchershop
  • 1 year later...
Depends on what you want... You can get a stock, ready to run, Axial SCX10 for around $300. Add $50 for the MJ body and paint. Actually, a factory SCX10 is dang capable and rock solid. Drive it until you feel the need to upgrade. Winches, scale accessories, aluminum steering, aluminum suspension, shocks, driveshafts, LiPo batteries, ESC, motor, axles, knuckles, etc. It could easily exceed $1000, but whose counting?
I've been wanting to build this and a back yard trail over the summer,
any good, recommended places on line to get this stuff?
I'm a compete rc newb :)
You can pick up most of this online. I like Tower Hobbies. When you spend enough, you can pick up some good discount codes on retailmenot.com .
As Brett said, you can get as crazy as you want with these. You can run them straight out of the box in a Ready To Run (RTR), or you can get the kit and build it yourself. Everything after that is an upgrade... Motor, trans, transfercase, front dig box, axle shafts, knuckles, hubs, wheels/tires, long arm... Anything...
Here are some pics of mine when I was rebuilding it after buying it used and abused:
427719_321936804510480_977995609_n.jpg?o
Rob
I am still very much a newb, even though I have had my rig for almost 4 years.  :dunno:
Check out RC Crawler
Just was with the full size rigs, you will learn a ton by reading various truck builds. The MJ body fits perfectly on the Axial SCX10 so you will find a lot of relevant information in the scale rigs forum.
February 2014
August 2013
Automan2164-  Is there a good place (besides CL) to look for a used scx10 in our local area?
So Cool... I want to come check yours out when it gets warmer.
CL is best, eBay is second best, but buyer beware... This is the kind of thing you want to see in person, or be dealing with someone who likes to take a lot of pics. I spent hours rebuilding mine after buying it from my roommate who found out the hard way. Bought it off eBay, and they guy misrepresented it. Hack wiring, hack body, hack 'Water proofing' (either covered in liquid electrical tape, or inside a zip tied balloon covered in liquid tape), dry washed out bearings, dirt everywhere, dry transmission, bent motor mount plate... I ended up going through it tip to tail with new bearings, front driveshaft, motor plate, spent hours picking off the tape and cutting out the balloons, cutting off all the hack excess wiring...
Wiring is a huge pet-peeve of mine, as part of my job entails upfitting squad cars... This made me want to stab someone.
Bent motor plate:
Dry trans:
Dirt in everything, seized bearings:
Wiring all said and done. Cut out all the stupid excess lights, unnecessary items, and soldered everything.
All said and done, CL would be the best bet.
I am surprised our own Neohic hasn't already picked up one of these bodies and put it on a car chassis to do a mini archer truck... Ben? :brows:
Rob
Deals are out there. I was lucky enough to pick up my like new SCX10 from craigslist for $150. Included battery, weighted wheels and scale swampers. It had only been run a few times. The truck wasn't a good competition crawler so the guy wanted it gone.
Image Not Found
