1J7Fj36S3Ml570755
gogmorgo
1991 Jeep Comanche Pioneer (according to http://www.decodethi...7FJ36S3ML570755)
http://comancheclub....ian-91-longbed/ <-- more pics and updates
4.0 HO, Auto, LWB
Current location: Saskatoon SK
Status: 475xxxkm, (~295k miles), Manitoba plated. Needs a lot of (mostly cosmetic) work, but runs and drives great. I'd say it's an ongoing project.
Current owner: Me!
Notes: Dark blue paint that goes purple from the right angle (not original). Grey interior, vinyl buckets, floor shifter, cluster w/ tach. Looks like it may have done duty as a pilot vehicle (those silly orange lights on the front that I can't figure out how to make work, plus cb antenna mount and cable and very high mileage), maybe in the service of Parks Canada (just a guess based on the fact that it's the same colour as the older Parks trucks and the PO bought it in a town that may as well be in a national park, it's close enough). Supposedly ~150 km on an engine rebuild. Body is pretty straight but the rockers are mostly bondo and there's rust starting in a few places, but nothing major.
I'm guessing it's spent a good portion of it's time on the highways, but the paint's been redone, likely within the last five years or so. The front clip's also been taken apart at some point, and I know that because of the rusty ratchet option on one of the bolts near the headlight. :brows: The PO put about a grand of work into it in the last year, too, although mostly drivetrain stuff.
The rockers are a friggen mess of bondo, though, especially the passenger side. The interior isn't in the greatest shape either, and I've yet to pull up my carpets, but judging by the rockers, I don't expect it to be good...
But overall, yeah, it's in pretty good shape. Definitely some miles on her, everything does work, though. But to paraphrase Dylan, half of it partly works all of the time, and some of it works all right part of the time, but everything doesn't work all right all the time...
My dream is to fix that if anyone wants to be in it. ;)
  • 6 years later...
*A8 TRIM STYLE A8 - VINYL LOW BACK BUCKET ST
-SA CHARCOAL
125 Zone 25-Canada-Alberta
1AB Canada Dealer Retail
3N8 Drive Away Program Tracking
4CP Federal A/C Excise Tax
4HC Special Scheduling Condition III
ACC Southwest Edition
ADA Light Group
ADL Skid Plate Group
APA Monotone Paint
ARL 300 Premium Group
BAF 130 Amp Alternator
BCY 475 AMP BATTERY
BGA Power Front Disc/Rear Drum Brakes
CAC Low Back Bucket Seats
CDB Reclining Front Seats
CKA Carpets - Floor and Cargo Area
CUM Mini Floor Console
DGB All 4-Speed Automatic Transmissions
DGS 4-Speed Automatic AW4 Transmission
DHA Lock-Up Torque Converter
DHN Command-Trac Part Time 4WD System
DHS Floor Mount Automatic Shift Lever
DJH 230MM Front Axle
DMD 3.55 Rear Axle Ratio
DRJ 175MM Rear Axle
ERH 4.0L I6 Power Tech Engine
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GFD Rear Sliding Window
GNC Sun Visors w/Illum Vanity Mirrors
GRZ Left Remote Mirror
GSZ Right Remote Control Mirror
GTZ Manual Remote Mirrors
HAA Air Conditioning
JAY DO NOT USE - See JP, KA classes
JDB 180 KPH Primary Speedometer
JGB Digital Clock
JHA Var Intermittent Windshield Wipers
JJA Cigar Lighter
K27 Do Not Use
K2B STRIPE/BADGE/MOLDING/COLOR
K3L STRIPE/BADGE/MOLDING/COLOR
KKS STRIPE/BADGE/MOLDING/COLOR
KWS STRIPE/BADGE/MOLDING/COLOR
LAJ Headlamps On Warning Chimes
LBB Courtesy Lamps
LBC Glove Box Lamp
LBD Ash Tray Lamp
LBE Door Armrest Storage Lamp
LDA Underhood Lamp
LHD Headlamp Off Time Delay
LMA Halogen Headlamps
LMK Daytime Running Headlamps, High Beam
MB1 Black Front Bumper
MBJ Black Powder Coated Front Bumper
MDA Front License Plate Bracket
MFF Black Grille
MHA Black Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMK Lower Grille Surround-Painted Silver
NAA Federal Emissions
NBK EVAP Control System
NF5 Fuel Tank - 23 Gallon
NHK Engine Block Heater
NHM Speed Control
PB8 MIDNIGHT BLUE MET CC PRI PNT - HB8
QB8 SECONDARY PAINT
RAA All Radio Equipped Vehicles
RAF AM/FM Cassette Radio
RCD 4 Speakers
SBA Power Rack and Pinion Steering
SCE Alcantara Wrap Steering Wheel
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
SUA Tilt Steering Column
TBB Full Size Spare Tire
TBM Tire Carrier Winch
TRN P225/75R15 OWL Wrangler AT Tires
TZA Goodyear Brand Tires
WJN 15" Aluminum Wheels
WLZ All Aluminum Wheels
XBS Pickup Box
YAC Build To Canada Mkt. Specifications
YGA Without Billable Fuel
Z01 Rear Spring Group I
Z5A GVW/Payload Rating
Z67 Left Front Spring Group XVI
Z86 Right Front Spring Group XV
Body Model JL62
Build Date 1/21/91
  • 1 year later...
