Winchesterjeep Posted September 29, 2012 Posted September 29, 2012 Wondering if anyone has encountered similar electrical issues. I think I have a bad ground somewhere. It cranks alright, but turn, brake and several other electrical systems not working. Fuses all good and directly placing current into the circuit doesn't do anything. Any thoughts? Ordering the shop manuals and complete electrical schematics. '87 MJ I-6 shortbed Just starting restoration on it
cruiser54 Posted September 30, 2012 Posted September 30, 2012 Renix Ground Refreshing The Renix era XJs and MJs were built with an under-engineered grounding system for the engine/transmission electronics. One problem in particular involves the multiple ground connection at the engine dipstick tube stud. A poor ground here can cause a multitude of driveabililty issues, wasted time, and wasted money replacing unnecessary components. The components grounding at the dipstick tube stud are: Distributor Sync Sensor, TCU main ground, TCU “Shift Point Logic”, Ignition control Module, Injectors, ECU main ground which other engine sensors ground through, Oxygen sensor, Knock Sensor, Cruise Control, and Transmission Sync signal. All extremely important stuff. The factory was aware of the issues with this ground point and addressed it by suggesting the following: Remove the nut holding the wire terminals to the stud. Verify that the stud is indeed tightened securely into the block. Scrape any and all paint from the stud’s mounting surface where the wires will attach. Must be clean, shiny and free of any oil, grease, or paint. Inspect the wire terminals. Check to see that none of the terminals are crimped over wire insulation instead of bare wire. Be sure the crimps are tight. It wouldn’t hurt to re-crimp them just as a matter of course. Sand and polish the wire terminals until clean and shiny on both sides. Reinstall all the wires to the stud and tighten the nut down securely. While you’re in that general area, locate the battery negative cable which is fastened to the engine block just forward of the dipstick stud. Remove the bolt, scrape the block to bare metal, clean and polish the cable terminal, and reattach securely. Another area where the grounding system on Renix era Jeeps was lacking is the engine to chassis ground. There is a braided cable from the back of the cylinder head that also attaches to the driver’s side of the firewall. This cable is undersized for it’s intended use and subject to corrosion and poor connections at each end. First off, remove the cable end from the firewall using a 15mm wrench or socket. Scrape the paint off down to bare metal and clean the wire terminal. Reattach securely. Remove the other end of the cable from the rear of the head using a 3’4” socket. Clean all the oil, paint and crud from the stud. Clean the wire terminal of the cable and reattach securely. A suggestion regarding the braided cable: I prefer to add a #4 Gauge cable from the firewall to a bolt on the rear of the intake manifold, either to a heat shield bolt or fuel rail bolt. A cable about 18” long with a 3/8” lug on each end works great and you can get one at any parts store already made up. Napa has them as part number 781116. A further improvement to the grounding system can be made using a #4 cable, about 10” long with 3/8” terminals at each end. Attach one end of this cable to the negative battery bolt and the other end under the closest 10mm headed bolt on the radiator support just forward of the battery. Napa part number 781115. If you want to upgrade your grounds and battery cables in general, contact Jon at www.kelleyswip.com. He makes an incredible cable upgrade for a very reasonable price. Revised 11-28-2011
cruiser54 Posted September 30, 2012 Posted September 30, 2012 Renix Jeep C101 Connector Refreshing The C101 connector on 1987 and 1988 Renix Jeeps was a source of electrical resistance when the vehicles were new. So much so that the factory eliminated this connector in the 1989 and 1990 models. The factory recommended cleaning this connector to insure the proper voltage and ground signals between the ECU and the fuel injection sensors. We can only imagine how this connector has become a larger source of voltage loss and increased resistance over a period of almost 25 years. The C101 connector needs to be cleaned at least once in the lifetime of your vehicle. Chances are it’s never been done before. Almost every critical signal between the engine sensors, injectors, ECU, and some to the TCU, travel this path through the C101 connector. The C101 connector is located on the driver’s side firewall above and behind the brake booster. It is held together with a single bolt in it’s center. To get the connectors apart, simply remove the bolt and pull the halves apart. You will find the connector is packed with a black tar like substance which has hardened over time. Take a pocket screwdriver or the like and scrape out all the tar crap you can. Follow up by spraying out both connector halves with brake cleaner and then swabbing out the remainder of the tar. Repeat this procedure until the tar is totally removed. This may require 3 or more repetitions. Wipe out the connectors after spraying with a soft cloth. If you have a small pick or dental tool, tweak the female connectors on the one side so they grab the pins on the opposite side a bit tighter before bolting both halves back together. Revised 07-17-2012
JeepnDale Posted September 30, 2012 Posted September 30, 2012 Hi folks, Ever encounter this one? Starting to go through my recent purchase, an 89 MJ, still not sure exactly what it is, because the vin # doesn't make any sense...I'll ask that question on another related thread. Anyways, all the lights work except the tail lights. I replaced the bulbs, then checked the fuse....it was gone....hmmmm...... took the 10amp clock fuse and replaced it. YAY! they worked! THEN, I tried to start it.......nothing.....again, nothing. Took out the fuse I just put in, and it's blown, and now the truck starts fine....crap. I hate electrical issues. Anyone help?
HOrnbrod Posted September 30, 2012 Posted September 30, 2012 The fuel pump and tail lamps are grounded by a single sheet metal screw behind the left tail lamp. Try pulling the lamp and check for a good ground and/or any skinned wires at the harness.
87MJTIM Posted October 1, 2012 Posted October 1, 2012 http://comancheclub....ctrical-manual/ The thread has a link to the complete wiring diagrams for an '88 MJ. I have an "87 and found that the wiring is the same. Whenever I have an electrical problem, this is what I turn to. I downloaded it and printed it out. Hope it helps.
cz777 Posted October 1, 2012 Posted October 1, 2012 may i add beef up your ground circuits with lugged battery cables one to engine next to body ....i have done both thxs to cruiser54 earlier post over this same issue ....one more thing is look at the fuse box area for other troubles like brake fluid hitting it ....rust trails too !!!
Winchesterjeep Posted October 6, 2012 Author Posted October 6, 2012 Thanks everyone for the help! I'm going to give it a try this morning and will report back.
Winchesterjeep Posted October 7, 2012 Author Posted October 7, 2012 Ok, looks like I found a few minor gremlins today.fuses. 1. Fuse blades were oxidized in some cases or corroded in others. They still tested ok, but went ahead and replaced all 2. Front pass. turn signal socket was corroded and contacts were crossed. (Anybody have a lspare laying around?) 3. Prior owner used scotch locks to attach a trailer harness. These should be banned along with tworucture.-pronged cords. Not sure if all else is working yet, but I double checking all grounds and will upgrade the main grounding infrastructure.
cruiser54 Posted October 7, 2012 Posted October 7, 2012 I suggest unplugging EVERY electrical connection in the engine bay you can find, whether engine related or not, and spraying it out with a good electronics cleaner, visually inspecting the terminals making sure they haven’t retracted into the plastic holder, and then plugging it back together. There’s a critical 10-pin connector for the front lighting system located in front of the air cleaner and behind the left headlight assembly. Don’t miss that one. Also be sure that the connectors to the ballast resistor mounted near the air cleaner housing are clean and tight. ALL of the relays should be removed, the terminals wire-brushed until shiny, and the receptacles sprayed out with contact cleaner. Then plug them back in. I do this on every Renix Jeep I purchase or work on for someone else. Revised 07/23/2012
