Zenobian_84 Posted September 11, 2012 Share Posted September 11, 2012 Mine are in serious need of replacement, and since I was going to get two new headlights, I figured I may as well replace them while I was at it. After a bit of searching around, I found there is no specific Jeep replacement, and that these are "Universal Sealed Beam Adjusters" (Dorman PN: 42117) Would these be what I'm looking for? Also since I can't seem to locate my repair manual at the moment, how do you change these out (I'm assuming they're all changed the same way)? Just so I don't unintentionally screw anything up while I'm fiddling around with them. :thwak: Never hurts to make sure. :dunno: Link to comment Share on other sites More sharing options...
Jeep Driver Posted September 11, 2012 Share Posted September 11, 2012 These type of items are what I call 'pocket parts' at the local picknpull. Link to comment Share on other sites More sharing options...
Zenobian_84 Posted September 11, 2012 Author Share Posted September 11, 2012 These type of items are what I call 'pocket parts' at the local picknpull. Haha, I know; but the ones at the yards are usually in much worse shape than mine! :yes: Link to comment Share on other sites More sharing options...
Jeep Driver Posted September 11, 2012 Share Posted September 11, 2012 Those are common parts at parts stores also. Got mine from a 98XJ......were just fine. Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 11, 2012 Share Posted September 11, 2012 Mine are in serious need of replacement, and since I was going to get two new headlights, I figured I may as well replace them while I was at it. After a bit of searching around, I found there is no specific Jeep replacement, and that these are "Universal Sealed Beam Adjusters" (Dorman PN: 42117) Would these be what I'm looking for? Also since I can't seem to locate my repair manual at the moment, how do you change these out (I'm assuming they're all changed the same way)? Just so I don't unintentionally screw anything up while I'm fiddling around with them. :thwak: Never hurts to make sure. :dunno: Do your's look like these: http://www.o.teamgra...screws&catid=95 Link to comment Share on other sites More sharing options...
Dirteatr717 Posted September 11, 2012 Share Posted September 11, 2012 If you need one let me know! I saved 2 from my broken header panel and kept them as spares Link to comment Share on other sites More sharing options...
aaronbtxnc Posted September 11, 2012 Share Posted September 11, 2012 It's a PITA to replace the little plastic "sockets" that the actual screws go in to. I had my 9 year old try to help since her hands are so small, but ended up wedging them on a really long scredriver to get them in position. It would probably be much easier if you remove the light housing/socket thingy (the metal part just behind the light). Link to comment Share on other sites More sharing options...
Zenobian_84 Posted September 11, 2012 Author Share Posted September 11, 2012 Do your's look like these: http://www.o.teamgra...screws&catid=95 Sure do Don. Are the screws and clips supposed to come as one unit? Or are they 2 piece setup? Link to comment Share on other sites More sharing options...
Eagle Posted September 11, 2012 Share Posted September 11, 2012 The screws and nylon clips usually come as an assembly. All the aftermarket ones I've seen were too short, and I had to buy genuine Jeep parts. That was awhile ago, and I don't know if Mopar still has them in the system. Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 11, 2012 Share Posted September 11, 2012 The screws and nylon clips usually come as an assembly. All the aftermarket ones I've seen were too short, and I had to buy genuine Jeep parts. That was awhile ago, and I don't know if Mopar still has them in the system. These are genuine OEM parts and work fine. http://www.o.teamgra...screws&catid=95 Link to comment Share on other sites More sharing options...
Zenobian_84 Posted September 11, 2012 Author Share Posted September 11, 2012 These are genuine OEM parts and work fine. http://www.o.teamgra...screws&catid=95 :thumbsup: Good to know. Thanks for the help everyone; I'll be placing an order for a set or two later this week. Link to comment Share on other sites More sharing options...
Eagle Posted September 12, 2012 Share Posted September 12, 2012 That's a great price for the complete set. Link to comment Share on other sites More sharing options...
NickS Posted August 19, 2018 Share Posted August 19, 2018 Anyone know where these can still be found? One of my headlights keep falling down. Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 19, 2018 Share Posted August 19, 2018 3 minutes ago, AntiNicker said: Anyone know where these can still be found? One of my headlights keep falling down. HERE Link to comment Share on other sites More sharing options...
NickS Posted August 19, 2018 Share Posted August 19, 2018 Thanks! Will those work for an 88? Says 91-01. Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 19, 2018 Share Posted August 19, 2018 5 hours ago, AntiNicker said: Thanks! Will those will work for an 88? Says 91-01. Yes. Link to comment Share on other sites More sharing options...
NickS Posted August 19, 2018 Share Posted August 19, 2018 Awesome. I appreciate the help. Link to comment Share on other sites More sharing options...
