Pete M Posted August 23, 2012 Share Posted August 23, 2012 3" starts to need all sorts of stuff (longer track bar, shocks, brakelines, etc). 2" just needs spacers and either an AAL rear or the chevy shackle. :thumbsup: and 31s can be run on a stock MJ as long as you stick with Jeep rims so a whole 3" isn't needed. Link to comment Share on other sites More sharing options...
89Patches Posted August 23, 2012 Share Posted August 23, 2012 First thing to do is toss the vacuumm disconnect and atleast upgrade your gears to 3.55's... and lsd but for a good DD 3 inch would be good on road and off road, and cheap Link to comment Share on other sites More sharing options...
ComancheKid45 Posted August 24, 2012 Share Posted August 24, 2012 I'm around 3" of lift on my Blue truck and Its plenty capable. Youll notice better improvement off road with the likes of Armor and Lockers than you will with a large lift and tires and open diffs ;) Just for the record my truck got everywhere the Wranglers of the group on 33-37" tires did my last trip to Rausch, just need a good spotter and patinence :thumbsup: Link to comment Share on other sites More sharing options...
Dedaw Posted August 25, 2012 Author Share Posted August 25, 2012 Thanks for all the replies, guys! I love the look of bigger lifted trucks, but since I've never been wheeling, might as well get something that'll just get me down the trail to start. And THEN build a better wheeler when I have two vehicles. Next paycheck, I'm thinking of going with: Teraflex 2" spacers from Quadratec ($50) Chevy shackles (Guessing JY?) Rancho RS500 shocks from shockwarehouse on all 4 corners ($240) Rancho RS5401 Steering stabilizer from shockwarehouse ($60) My shocks are almost certainly toast, so I figured while I'm down there I might as well put those on too. Now to find cheap tires... EDIT: Also need to start going through my engine, and making sure I don't have a rod knock. If I do, this will be very short lived. Maybe I should make a build thread now. :clapping: Link to comment Share on other sites More sharing options...
Pete M Posted August 25, 2012 Share Posted August 25, 2012 not regular chevy shackles you want the drop shackles, which are longer. any parts store should have them. :thumbsup: Link to comment Share on other sites More sharing options...
Dedaw Posted August 25, 2012 Author Share Posted August 25, 2012 not regular chevy shackles you want the drop shackles, which are longer. any parts store should have them. :thumbsup: Thanks for clarifying, that could've been interesting. :D Link to comment Share on other sites More sharing options...
Pete M Posted August 25, 2012 Share Posted August 25, 2012 also, if you have any issues with the leaf spring bolts and need new ones, they are the same as lower control arm bolts (which tend to be in better shape at the junkyards) :thumbsup: Link to comment Share on other sites More sharing options...
Dedaw Posted August 25, 2012 Author Share Posted August 25, 2012 Awesome! Thanks again! :thumbsup: Link to comment Share on other sites More sharing options...
Dedaw Posted August 27, 2012 Author Share Posted August 27, 2012 Got offered 4.10s for free and a set of 31s for $150. Might have to jump on that. Buuuut, took the truck to a shop and got diagnosed a rod knock. So I'm waiting to figure out what I'm gonna do. :thumbsup: Link to comment Share on other sites More sharing options...
xeducatex Posted September 6, 2012 Share Posted September 6, 2012 What r ur guys thoughts on the ranco 4.5 inch lift kit. Looking for the same as op....a dd that has all around skillz Id like to fit 33s as well but I'm not quite sold on the soa.....curious what the pros and cons are for soa or no soa? Also if I were to get the 4.5 in lift with 33s would I have to replace the d35 And antidisestablishmentarianism is a oem lift and why is it so good? Whats the difference between rough country and oem? Link to comment Share on other sites More sharing options...
Blue88Comanche Posted September 6, 2012 Share Posted September 6, 2012 Also if I were to get the 4.5 in lift with 33s would I have to replace the d35 it would be a good idea to replace your D35 axle while running anything larger than stock tires. Link to comment Share on other sites More sharing options...
