not big but small tires
so i want to know if i get some old wheels (those steel stamped kind) and put some lower profile tires on them would it work?
see I'm really in to auto x and i used to do it in my old neon, well this season is coming up and i want to race. well i think my truck might sit too high so if i got some tires that have a smaller side wall i think it might lower it enough to race. the problem I'm having is i am not sure if the tires could hold the weight of my truck (I'm not sure how much they weigh) it is nkot a "big" truck so i just want to know if it will work?
yeah, but a short sidewall tire on a 14" rim would have two advantages.
It would lower the entire turck, thus moving your CG down.
It would effectively give you a gear ratio increase.
I agree with you on that, but his engine/trans setup might prefer a taller gear setup (ie taller tires), and the height that you lose would be rather small, and with a truck like this, the extra unsprung weight in wheels and tires would more than likely be a benefit.
To be honest though, I would just find an older rwd v8 car and gut it and do some odds and ends; you're gonna end up over your head in this deal, IMHO
I'd get some used 15x8 steelies and a used set of wide-ish car tires for them. Something about 9 inches across would be nice. :D Then I'd put some effort into hooking up a rear anti-sway bar and put out the cash for some quality shocks. Then it's just a matter of making sure the rest of the truck is good-to-go and then I'd get out and have some fun. jamminz.gif
The spring rate issue could be solved by using something i have used in the past. Its a set of coil springs thqat you setup with bolt on clamps to your shock tubes. I used it to lift my truck back when i only had about 50 bucks to do it. They were at advanced auto and worked well. The don't give any lift unless you install them compressed and then bolt them on thus it holds the shock at almost full exstention(sp??) but if you install them how they are suposed to be it will work how you are needing. Oh and this is for the rear of the jeep the front is as easy as finding a set of coils for a full size and cutting them to length. Just a quick thought i had. Good luck.
Cole
I run 33" with an SOA and the extra spring stiffness REALLY lets me cruise the corners! I do the ramp from I-405 southbound onto I-520 eastbound (towards Microsoft) at 50 mph when the ramp is clear. I've watched more than one R Honda go off the corner or spin out trying to keep up!
:D
Cole
So it basically turns them into a Macpherson strut?
Welcome back to the forum Cole! :USAflag: jamminz.gif
My '87 shortbed came with a swaybar (someone swiped the D44 before I got it) I tossed it when I did the SOA. Didn't think they were anything special? (I'm using the spring plates to mount my shocks on)
Factory in the rear? Hornbrod was looking for one awhile back, and considered modifying an XJ bar since no one made one.
