HKB3 Posted July 30, 2012 Posted July 30, 2012 I need to replace the front brakes on my Comanche, it is a 92 2wd. Just wanted to know if 4 wheel drive share the same rotors/calipers as the 2wd. I have not really looked at the truck yet but it appears that it has a unit bearing just like a 4wd without the stub shaft. The reason I am asking is I have a 4wd swap planned down the road and don't want to buy parts twice.
jimoshel Posted July 30, 2012 Posted July 30, 2012 What I do on something like this is check the part numbers. Either go online to one of the auto parts stores , or get one of their catalogs. Look up the part numbers of the old part. Then get the number for the new part. If it's the same number, they'll interchange. I have found that sometimes the numbers will be different but the part will still fit. Usually a small change and the new part will fit the old application but the old part won't fit the newer.
Rymanrph Posted July 30, 2012 Posted July 30, 2012 When I did the 4wd conversion on my '90, the old 2wd calipers wouldn't work on my '97 Dana 30. I believe the 4wd calipers are a little bigger.
mvusse Posted July 30, 2012 Posted July 30, 2012 calipers and brake pads (and rotors, I believe) changed between 90/91. But for the same year, there is no difference between 4wd and 2wd brakes.
Blue88Comanche Posted July 31, 2012 Posted July 31, 2012 on our 88 and 89 the rotors are different.. dad's 2wd had the hub bearings and studs attached to the rotor itself where as the rotor on my 4wd slides onto the hub and the lug studs pass through the rotor. 2wd bearing note the studs attached to the rotor on the 2wd rotors 4wd hub (borrowed from cherokeecorum.com) 4wd rotor
HOrnbrod Posted July 31, 2012 Posted July 31, 2012 On the 2WD MJs, the one piece rotor/hub shown above (w. the wheel studs) was used through the 1992 models. Starting in 1993 the 2WD and 4WD rotors became the same. The 2WD calipers were the same up to midyear 1992-1/2, after that they changed to the same calipers as the 4WD models. I'm sure there was overlap too.
Eagle Posted July 31, 2012 Posted July 31, 2012 I need to replace the front brakes on my Comanche, it is a 92 2wd. Just wanted to know if 4 wheel drive share the same rotors/calipers as the 2wd. I have not really looked at the truck yet but it appears that it has a unit bearing just like a 4wd without the stub shaft. The reason I am asking is I have a 4wd swap planned down the road and don't want to buy parts twice. They are the same year-for-year, but there are differences between/among different years, and you cannot mix-and-match without running into problems.
HKB3 Posted July 31, 2012 Author Posted July 31, 2012 Thanks for the info, after pulling the wheels I found that mine is like in the pic above which is nit the same as a 4wd. On a side note I just picked up a wagoneer front Dana 44. w00t!!!
1986Comanche Posted August 2, 2012 Posted August 2, 2012 On the 2WD MJs, the one piece rotor/hub shown above (w. the wheel studs) was used through the 1992 models. Starting in 1993 the 2WD and 4WD rotors became the same. The 2WD calipers were the same up to midyear 1992-1/2, after that they changed to the same calipers as the 4WD models. I'm sure there was overlap too. Some 2WD Comanches have the 2 piece rotor and hub setup like the 4WD Comanches. My 1986 2WD Comanche has the 2 piece setup like a 4WD. They used both styles in 1986.
