Diy E-Brake Fix
2 dock washers (not a misspelling) to replace the hump if you had to cut it out, they look just like normal washers just really thick, ask about em COST: about 7 bucks.
One 2 1/2 inch bolt to replace the pin that held the secondary bracket, pedal and main bracket together, make sure it is as tight a fit as you can find, *get a grade 3 bolt and a grade 8 standard nut, i will explain later
What size dock washer, and what size bolt? "2 1/2 inch" is not a size, it's a length.
  • 6 months later...
It might be just enough to pass state safety tests or whatever that is.  But for a permenant fix this writeup is the only one i know about.
EDIT: Something that might help without completely dismantleing the assembly is to replace the small retaining spring that holds the keeper arm against the pedal.
Are you thinking that a heavier duty small retaining spring could be a total cure?
  • 4 months later...
