kurt Posted July 19, 2012 Share Posted July 19, 2012 any one knows how to remove the door key hole ? Link to comment Share on other sites More sharing options...
jimoshel Posted July 19, 2012 Share Posted July 19, 2012 Take a pair of tin snips and cut around it. Or if you don't want a bigger hole then weld a plug into it. Link to comment Share on other sites More sharing options...
Backdraft Posted July 19, 2012 Share Posted July 19, 2012 :rotfl2: Link to comment Share on other sites More sharing options...
vaquaro Posted July 19, 2012 Share Posted July 19, 2012 any one knows how to remove the door key hole ? Would you like to re-phrase / re-think the question :huh???: Link to comment Share on other sites More sharing options...
cruiser54 Posted July 19, 2012 Share Posted July 19, 2012 Napa used to carry a key hole remover product. You might wander into a store near you and see if they have some on the shelf. Should be right next to the belt stretcher. Link to comment Share on other sites More sharing options...
lostissues Posted July 19, 2012 Share Posted July 19, 2012 if your talking about the whole dot where you insert the key on the door then you have to get to the inside of the door. look around in there with a flashlight and mirrors if you cannot see it well. it is held on by a bent piece of metal that is slid around it to hold it in place, you have to pull or hammer it out (carefully because the window will be in the same area) and then you will be able to pull it out from the outside. http://www.justanswer.com/jeep/2sn5h-ke ... -it-s.html Link to comment Share on other sites More sharing options...
kurt Posted July 19, 2012 Author Share Posted July 19, 2012 thanks a lot guys :) Link to comment Share on other sites More sharing options...
carnuck Posted July 20, 2012 Share Posted July 20, 2012 Napa used to carry a key hole remover product. You might wander into a store near you and see if they have some on the shelf. Should be right next to the belt stretcher. And blinker fluid as well as muffler bearings! Link to comment Share on other sites More sharing options...
vaquaro Posted July 20, 2012 Share Posted July 20, 2012 And for you sailors : Green oil for the starboard lights & Red oil for the port lights :cheers: Link to comment Share on other sites More sharing options...
Harley Posted July 20, 2012 Share Posted July 20, 2012 Don't forget the piston return springs! :thumbsup: Link to comment Share on other sites More sharing options...
Keyav8r Posted July 22, 2012 Share Posted July 22, 2012 Don't forget the skyhooks - invaluable if you need to pull an engine outdoors or get hard stuck while wheeling. They are usually kept under the counter so they don't float up against the ceiling. Link to comment Share on other sites More sharing options...
