JFAComanche6 Posted June 8, 2012 Share Posted June 8, 2012 Can I use a front Dana 30 off of a 1993 grand cherokee ZJ bodystyle on my 89 MJ? Link to comment Share on other sites More sharing options...
Backdraft Posted June 8, 2012 Share Posted June 8, 2012 No, but you can use a front Dana 30 from a ZJ. Link to comment Share on other sites More sharing options...
JFAComanche6 Posted June 8, 2012 Author Share Posted June 8, 2012 my bad thats what I meant...alright thanks. Link to comment Share on other sites More sharing options...
Pete M Posted June 8, 2012 Share Posted June 8, 2012 the ZJ axle will bolt up, and will be fine for stock trucks, but its low pinion and that can become an issue on lifted truck. plus some of them came with CV joints. once again fine for street trucks, less good for lifted. Link to comment Share on other sites More sharing options...
mvusse Posted June 10, 2012 Share Posted June 10, 2012 Shafts can be swapped. Link to comment Share on other sites More sharing options...
JFAComanche6 Posted June 10, 2012 Author Share Posted June 10, 2012 I don't plan to lift the truck anytime soon, I'm just tired of getting stuck on wet grass :fs1: I'm also wanting the stock 3.07 front axle too so I can use 4wd on the road and I don't want to mess with my stock rear end. Link to comment Share on other sites More sharing options...
Eagle Posted June 11, 2012 Share Posted June 11, 2012 JFAComanche6 said: I don't plan to lift the truck anytime soon, I'm just tired of getting stuck on wet grass :fs1: I'm also wanting the stock 3.07 front axle too so I can use 4wd on the road and I don't want to mess with my stock rear end. You won't find 3.07 gears in a ZJ, unless you find one of the EXTREMELY rare 1993s with a 5-speed. That was the only year Jeep offered a manual transmission in the ZJ. All others are automatic and will have either 3.54s or 3.73s. Link to comment Share on other sites More sharing options...
MJRemi Posted June 11, 2012 Share Posted June 11, 2012 Eagle said: JFAComanche6 said: I don't plan to lift the truck anytime soon, I'm just tired of getting stuck on wet grass :fs1: I'm also wanting the stock 3.07 front axle too so I can use 4wd on the road and I don't want to mess with my stock rear end. You won't find 3.07 gears in a ZJ, unless you find one of the EXTREMELY rare 1993s with a 5-speed. That was the only year Jeep offered a manual transmission in the ZJ. All others are automatic and will have either 3.54s or 3.73s. I thought this was unusual. http://inlandempire.craigslist.org/cto/3020282650.html Link to comment Share on other sites More sharing options...
JFAComanche6 Posted June 12, 2012 Author Share Posted June 12, 2012 Thats a nice ZJ...so what year XJs are most likely to have the 3.07 d30? This is pretty interesting. Link to comment Share on other sites More sharing options...
FrankTheDog Posted June 12, 2012 Share Posted June 12, 2012 JFAComanche6 said: Thats a nice ZJ...so what year XJs are most likely to have the 3.07 d30? This is pretty interesting. Any 87-01 with a manual. In order of desirability 95 1/2 - 99 (bigger u joints, non disconnect) Any 92-95 with abs brakes. (big ujoints,non disconnect) 87-91 disconnect . Link to comment Share on other sites More sharing options...
mvusse Posted June 12, 2012 Share Posted June 12, 2012 FrankTheDog said: JFAComanche6 said: Thats a nice ZJ...so what year XJs are most likely to have the 3.07 d30? This is pretty interesting. Any 87-01 with a 6 cylinder andmanual. In order of desirability 95 1/2 - 99 (bigger u joints, non disconnect) Any 92-95 with abs brakes. (big ujoints,non disconnect) 87-91 disconnect . 4 cylinder/manual transmission will have 3.55 or 4.10. Link to comment Share on other sites More sharing options...
Eagle Posted June 12, 2012 Share Posted June 12, 2012 MJRemi said: Eagle said: JFAComanche6 said: I don't plan to lift the truck anytime soon, I'm just tired of getting stuck on wet grass :fs1: I'm also wanting the stock 3.07 front axle too so I can use 4wd on the road and I don't want to mess with my stock rear end. You won't find 3.07 gears in a ZJ, unless you find one of the EXTREMELY rare 1993s with a 5-speed. That was the only year Jeep offered a manual transmission in the ZJ. All others are automatic and will have either 3.54s or 3.73s. I thought this was unusual. http://inlandempire.craigslist.org/cto/3020282650.html It's also not a rust bucket, which is also rare for the 93s. Being the first year for the ZJ body, there were some problem areas that were very prone to rust-through. I'm sure being a California vehicle doesn't hurt. Link to comment Share on other sites More sharing options...
