koooooooz Posted February 14, 2007 Posted February 14, 2007 A while back my truck was having problems starting. We after replacing coil distrubuiter and all the iginiton wires we went to the computer we rubed some Dio electric gresse on the terminial and it worked. super bowl sunday it had a little problems starting up but i got it going. it did the same things at my house agin the next week. and today it did it and we tried everything we would think of and it still won't crank we will probly have to get it towed i just want to know if yal have had this problem
mjeff87 Posted February 14, 2007 Posted February 14, 2007 CPS :dunno: It's cranking, but not starting, right?
Eagle Posted February 15, 2007 Posted February 15, 2007 How old is your CPS (Crankshaft Position Sensor)?
koooooooz Posted February 17, 2007 Author Posted February 17, 2007 we thought that was it and we replaced it and it is still doing the same thing could it just be a bad computer i am at my wits end
fiatslug87 Posted February 17, 2007 Posted February 17, 2007 CPS :dunno: It's cranking, but not starting, right? Is this correct? If it is, are you getting fuel? Can you hear the fuel pump prime when you turn the key? If you put fuel into the TB will it start? I had an intermittent no-start problem and it was a loose connection of the fuel pump wiring inside the cab near the emergency brake.
jared Posted February 18, 2007 Posted February 18, 2007 my xj would not start a couple times, just out of the blue. i have the auto aw4 in mine. it would not crank over or anything, it just played the radio etc, so the battery was not dead. it turned out i just had the move the gear selector to neutral and park a few times and it started right up, it was really cold outside when it did this.
Eagle Posted February 19, 2007 Posted February 19, 2007 ... today it did it and we tried everything we would think of and it still won't crank we will probly have to get it towed i just want to know if yal have had this problem What problem? Are you saying that it won't crank, or that it cranks but won't start?
Oizarod115 Posted February 19, 2007 Posted February 19, 2007 my xj would not start a couple times, just out of the blue. i have the auto aw4 in mine. it would not crank over or anything, it just played the radio etc, so the battery was not dead. it turned out i just had the move the gear selector to neutral and park a few times and it started right up, it was really cold outside when it did this. that's the NSS (nuetral safety switch) i bet your reverse lights don't work either? they can be cleaned, but i don't remember the writeup on how to do it. madxj probably. didn't 88swampedMJ have problems with his computer causing a no-start?
fiscus Posted February 19, 2007 Posted February 19, 2007 Sounds like the starter relay or starter itself if it's not even cranking. Or the CPS if it's cranking but not starting.
carnuck Posted February 23, 2007 Posted February 23, 2007 On the later models (90/92), there is a small wire next to the battery in a plug of it's own. Don't recall the color of the wire, but it was the lead to the starter. I put a bypass switch directly to it. I also found out that '93 (XJ) had the theft deterrent system (computer key under the dash) that I cleaned with electronic spray and didn't have a prob again.
koooooooz Posted February 24, 2007 Author Posted February 24, 2007 i think i have some of yal confused my truck has a problem that just comes up every once and a while. it will crank forever but it will not start. we have read online different things about CPS sensors we took the CPS off and went to and got a new one we put the new CPS in and it was still doing the same problem. we took the new CPS off and left it for about 5 days. we took back the new CPS and got our money back. I put the old one back in today and it started just fine i drove it around and it still would start. some times i wish it would just not work all the time so i could figure out what is wrong. i realized that my old CPS gromet was shot and i need to put a new one on Could that be the problem i just want to know what yal think ps it is a 91 jeep comanche inline 6, 5 speed stick
koooooooz Posted February 24, 2007 Author Posted February 24, 2007 ooh just 4 kix and giggles i went out and tried to start it up agin after it cooled off and it cranked but would not start go figure
fiatslug87 Posted February 25, 2007 Posted February 25, 2007 It would really help us and you, if you answered the questions we've been asking. Just repeating that you replaced the CPS doesn't really tell us anything new to go on.
