dasbulliwagen Posted May 8, 2012 Share Posted May 8, 2012 This is for a guy I work with on his 87 MJ Chief, short bed, 4x4, AW4, bucket seat, floor shift. He wants to keep it stock original working. The 4x4 light won't go off. We checked the elec switch and its working... getting vacuum all the time, so we thought it was the transfer case vac switch... replaced it and light is still on. Does anyone have a color coded diagram of the routing? I did a search and came up with nothing. Pretty sure Ive seen one before, but can't find it right now. Thanks. Link to comment Share on other sites More sharing options...
Motion Offroad Posted May 8, 2012 Share Posted May 8, 2012 Maybe this will help? Link to comment Share on other sites More sharing options...
dasbulliwagen Posted May 8, 2012 Author Share Posted May 8, 2012 Followed the lines, found the blue vent line attached to the violet line coming from the HVAC box. Now I need to know where the violet line attaches to. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted May 8, 2012 Author Share Posted May 8, 2012 found it.... heater control valve was the violet line, it was not hooked up. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted May 8, 2012 Author Share Posted May 8, 2012 THANK YOU MOTION OFFROAD!!! Link to comment Share on other sites More sharing options...
jeepcoma Posted May 10, 2012 Share Posted May 10, 2012 Wow. What a needlessly complicated system. I'm sure that had something to do with Jeep axing the CAD design. I can imagine many ham-fisted mechanics messing it up and owners complaining about things not working. Simple is better. Link to comment Share on other sites More sharing options...
carnuck Posted June 7, 2012 Share Posted June 7, 2012 Not to mention tearing the hoses loose on such rough offroad areas as speed bumps! Link to comment Share on other sites More sharing options...
Appstate97 Posted February 26, 2017 Share Posted February 26, 2017 I was replacing my floor pans and cut threw the 4x4 vacuum lines on the passenger side. The lines look similar to brake lines but aren't. What are my options for repairing the vacuum lines? Link to comment Share on other sites More sharing options...
omega_rugal Posted February 26, 2017 Share Posted February 26, 2017 too much of a mess... good they got rid of it... Link to comment Share on other sites More sharing options...
Eagle Posted February 26, 2017 Share Posted February 26, 2017 On 2/26/2017 at 3:28 AM, Appstate97 said: I was replacing my floor pans and cut threw the 4x4 vacuum lines on the passenger side. The lines look similar to brake lines but aren't. What are my options for repairing the vacuum lines? Cap the vacuum ports and lock the CAD in the engaged position. Link to comment Share on other sites More sharing options...
Appstate97 Posted February 26, 2017 Share Posted February 26, 2017 Is there any way to repair back to stock? What are the pros and cons of locking the cad system? Is a posi-lock a solution? Link to comment Share on other sites More sharing options...
Pete M Posted February 26, 2017 Share Posted February 26, 2017 those are vacuum lines you cut through. Just replace them if you want. But there are no measurable gains from keeping the CAD design. Jeep made a mistake when they installed it (they thought it would help with fuel economy, which it doesn't) and eventually did away with the system in the early 90s. It is not a locker of any kind, it just connects and disconnects the 2 pieces of the passenger side axle shaft. All Jeeps since the early 90s have a simple one-piece axle shaft in its place. There's a link to a way to bypass and fix the issue in the link in my signature. :thumbsup: Link to comment Share on other sites More sharing options...
