Brake Light in Dash
I am still trying to get my brakes right after the rear disc conversion and deleating the rear porportion valve. When I was pumping the brakes, the brake light came on in the dash and it will not go out. How do I get the light to go out?
Thanks
that light comes on if the pressure from front to back is different, mine came on once from the fluid level dropping, and even when filled up it took a month to go back off. brakes were fine though.
x2 what he said ^^
The same light warns that the parking brake is on and that there is a pressure imbalance between the front and the rear. First step, as noted above, is to make certain that the parking brake isn't on, not even a little bit. Assuming that's okay, if the light is on either the front brakes or the rear brakes have air in the lines, or have a leak.
The light went out, but I am still having issues with my brakes. I am certain that is was not the emergency brake. The reason I know is the light came on when I pushed the brake pedal and it went to the floor. It does that the first time you hit the brake, but after pump the brakes they are good. I also have plugged the bottem port on the block. So now I have just one new line going to the back with no prop valve. I know I have issues with the rear brakes because I clamped off the line going to the rear and I had great brakes. The rear brake set up I have is the TSM kit with the Cadillac eldo calipers and they are junk. This kit was on the rear axle when I bought it.
I finally drove it around my house and when I pulled it back into the garage I could smell brakes burning. It was coming from the right rear. I am going to have to replace that caliper and see what happens next. Before driving I gravity bled and also bled the brakes by having some one pump them. I got no air out of the back at all. I am at a loss of what is wrong. Hopefully it has something to do with the right rear claiper. Either way I have to replace it because it is dragging.
I agree with the air still in the lines. I have bled them alot. I have gravity bled and also had some one pump them up and still no air comes out. I am going to bleed them again once I replace the bad caliper and see what happens.
