Optimaldave Posted April 9, 2012 Share Posted April 9, 2012 Hi all. I have an 88 with the guages but no tach, and I have a line on a 93 cluster with all options. I know the 93 will have an electric speedo but is there a way to swap just the speedo's out or to convert from a mechanical drive speedo in the trans(2wd) to an electric output? Cheers Dave Link to comment Share on other sites More sharing options...
ComancheKid45 Posted April 9, 2012 Share Posted April 9, 2012 I know the speedo can be swapped easly. I'm unsure however if the rest of the cluster operates differently from the Renix era clusters :dunno: Link to comment Share on other sites More sharing options...
Geonovast Posted April 10, 2012 Share Posted April 10, 2012 The clusters are NOT compatible. Link to comment Share on other sites More sharing options...
Pete M Posted April 10, 2012 Share Posted April 10, 2012 yup, completely different wiring routing and gauge resistances. :thumbsup: Link to comment Share on other sites More sharing options...
Optimaldave Posted April 10, 2012 Author Share Posted April 10, 2012 Right, I just realized I was thinking of this backwards to how I'd do it as I would be using the new cluster and old speedo vs the old cluster and new speedo... Thus it was a stupid question as I knew the new cluster would not work in general... :wall: So never mind all Thank you Link to comment Share on other sites More sharing options...
Jeep Driver Posted April 10, 2012 Share Posted April 10, 2012 I have the 88 with what I believe is the cluster from a 90 with tach. Link to comment Share on other sites More sharing options...
Optimaldave Posted April 10, 2012 Author Share Posted April 10, 2012 I have the 88 with what I believe is the cluster from a 90 with tach. yes, but 1990 and before were the same cluster save for how the speedo cable attaches. The 93 donor I have though has a very different cluster that doesn't work in most ways vs just the speedo hookup. Link to comment Share on other sites More sharing options...
