big66440 Posted March 29, 2012 Posted March 29, 2012 My fuel pump ballast is getting extremely hot,would anyone have a clue why this is happening? would this cause my truck to stall randomly after a while of driving? it starts right back up, it just starting doing it out of the blue yesterday.
Eagle Posted March 29, 2012 Posted March 29, 2012 I've never checked the ballast resistor during or after operation, but it IS a resistor, and the nature of resistors is that they turn voltage into heat. Resistance generates heat, so what you're seeing may be perfectly normal.
Geonovast Posted March 29, 2012 Posted March 29, 2012 Hook up an ohmmeter to it. I'm not sure what the reading is supposed to be, but I imagine it's not supposed to be very high. My XJ doesn't have one, so I can't provide you with a reference, but I'm sure someone on here can.
HOrnbrod Posted March 29, 2012 Posted March 29, 2012 The resistance is right at 1.3 ohms. It is supposed to get hot, hot enough to burn you if you touch it. It's a wire-wound power resistor with a porcelain insulator to dissipate the heat. Clean the contacts well then check the resistance. They normally last forever if the contacts are kept shiny clean.
mvusse Posted March 29, 2012 Posted March 29, 2012 Plus it is optional to make the fuel pump a little quieter. My 87 never had one. If it is bad, just bypass it.
Exxon Valdez Jeep Posted March 30, 2012 Posted March 30, 2012 Mine was cracked in half and the truck would start and die, unless you held it at WOT, cuz I was told supposedly at WOT the pump bypasses that resistor. I replaced it with one off a cherokee and now its just noisy when I get low on gas.
cruiser54 Posted March 30, 2012 Posted March 30, 2012 In the name of science and mechanical research, I say we should all touch our ballast resistors after a half hour drive and report the findings back to this thread.
