Truck is stalling out
No he's not messing with you, look right below were the exhaust manifold bolts to the down pipe. Take it out hot and put it in cold so you have a better chance of not stripping out the threads. Buy a good one too and not a cheap unifit.
Ok thanks, i really thought he was saying like a muffler bearing or something....lolol
Pete:
I'm not sure.
In the exhaust manifold,.. Change the upstream ,.. Also look at the EGR
No EGR on his HO, and only one O2 sensor. Before you pull the O2 though do the other stuff as mentioned. Also unplug the cable connector and check the pins and sockets (4) on the O2 sensor harness for corrosion.
I would start with the free stuff. clean the TB and IAC with a throttle body cleaner (meaning O2 sensor safe) and an old toothbrush. :thumbsup:
I only have one toothbrush, so I use it for everything.
Thanks. Ill send you a new toothbrush if it works!!
So just pull the o2 sensor and check it for corrosion. Got it
Pull the sensor off itself also or just the plug?
Just the electrical connector to start. Also follow the harness up to where it goes into the fuel injector rail and make sure it's not fried or shorted. It passes pretty close to the exhaust manifold.
If everything electrically passes the eyeball test, might as well replace the O2 sensor. If it's the original it's overdue..............
Don, do the HO MJs trip a check engine light if the O2 sensor goes south?
The OBDI system is supposed to Pete, although I've never had one. The codes are as follows:
21: Oxygen sensor or circuit. O2 sensor or wiring faulty.
51: O2 detects lean mixture. Check sensor and circuit and for vacuum leaks.
52: O2 detects rich mixture. Check fuel injection system and sensor.
This is a good point, and I continually forget about it. To the original poster, do check the fault codes using the ignition key sequence as below to see if anything shows up that's not normal.
http://www.comancheclub.com/forums/viewtopic.php?f=9&t=29857
I'd drain the fuel filter and see how much water is in it.
Sometimes I get 2 or 3 tablespoons of water out of my filter.
Truck works real smooth till the next time it starts acting up.
