Blue88Comanche Posted January 31, 2012 Share Posted January 31, 2012 W couple weeks ago I moved the D44 from dad's MJ to mine, the parking brake was working fine for him. But now that its under my MJ its not working... I replaced all the brake hardware (springs, tension cable, and self adjuster), , adjusted the drum brakes, and adjusted the cable under the bed where it splits off to both brakes.... the parking brake lever is stiff to press, and will spring back kile it did in out F-250, but it seems to not be doing anything... the normal driving brake works fine. Link to comment Share on other sites More sharing options...
86customanche Posted January 31, 2012 Share Posted January 31, 2012 The teeth on the gear that clicks could be worn out. That's what has happened to my MJ, the teeth are worn out and the pressure when applying the parking brake is too much for what's left of those teeth. Link to comment Share on other sites More sharing options...
Blue88Comanche Posted January 31, 2012 Author Share Posted January 31, 2012 i replaced that as well... you are talking abut the one at the bottom, between the brakes right? Link to comment Share on other sites More sharing options...
maddzz1 Posted January 31, 2012 Share Posted January 31, 2012 i replaced that as well... you are talking abut the one at the bottom, between the brakes right? I think hes talking about the teeth on the parking brake lever itself. Where you press with your foot under the dash. Link to comment Share on other sites More sharing options...
MJRemi Posted January 31, 2012 Share Posted January 31, 2012 If you are sure the under-dash mechanism is functioning properly, have someone depress the pedal while you observe the splitter bracket cables. You should see what is or isn't moving during E brake operation and narrow down the problem. Link to comment Share on other sites More sharing options...
86customanche Posted February 1, 2012 Share Posted February 1, 2012 I think hes talking about the teeth on the parking brake lever itself. Where you press with your foot under the dash. That is was I was referring to. I was unclear to the original question about it springing back up. Link to comment Share on other sites More sharing options...
Eagle Posted February 1, 2012 Share Posted February 1, 2012 Did you replace any or all of the three cables? There's the front cable, and then the two from the equalizer to the two rear drums. Link to comment Share on other sites More sharing options...
Boots Posted February 1, 2012 Share Posted February 1, 2012 When I swaped in my d44 I didn't realize that the auto adjuster things are specific to which side they are on. My parking brake wouldn't work no matter how many times I tried to adjust them. Hope this helps Link to comment Share on other sites More sharing options...
Blue88Comanche Posted February 1, 2012 Author Share Posted February 1, 2012 I did not replace any of the cables under the jeep it self, just the ones to the self adjuster in the brake assembly. the "self Adjuster Cable" Link to comment Share on other sites More sharing options...
jeepdoggydogB Posted February 1, 2012 Share Posted February 1, 2012 I did not replace any of the cables under the jeep it self, just the ones to the self adjuster in the brake assembly. the "self Adjuster Cable" I have the Dana 44 and my parking brake has always performed strangely. Like you I replaced everything including the cables. The brake holds the truck from moving forward, but does not hold as well in keeping the truck from going backwards. Admittedly I have an old Ohio truck and the rear axle brake back-plates have rusted pretty good, even though I have replaced the brake hardware. I was lucky enough to grab some rust free back-plates from Don (hornbrod) last year, and when the rear pads wear out I will tear into the axle assembly and replace the plates. Hopefully this will help with the brake holding. :dunno: Link to comment Share on other sites More sharing options...
Eagle Posted February 1, 2012 Share Posted February 1, 2012 I did not replace any of the cables under the jeep it self, just the ones to the self adjuster in the brake assembly. Then that's likely the problem. If even one of the three is rusted up and doesn't move, the parking breakes don't work. The only thing worse is when they're rusted up and they DO move -- and then you can't release the parking brake :( Link to comment Share on other sites More sharing options...
