Drive shaft angle with SOA question
yup. but an SYE is out a bit more than it really should and still a great (albeit expensive cine you're on the hook for the kit plus a new driveshaft) upgrade. going SOA pulls the driveshaft out about an inch and in some cases this can cause problems in certain circumstances (especially if there is a lot of wear and slop at the yoke). since yours is a street queen, you should be fine. :thumbsup: in either case, a slightly longer driveshaft should return everything to normal.
One caveat, U-joints don't like crazy changes in their operating angles. you can get vibrations from that alone.
When I SOA'd mine, I needed a new rear d-shaft. A local speed shop fabbed one up for ~$100.
The factory rear shaft was so short, when I hit a gentle riser on the highway the shaft slipped all the way out of the tailcone, dropped to the ground and grenaded my rear end. I had to be flatbedded home.
Keep driveshaft angles in mind:
Although I"m by no means an expert, and I have never seen it done, theoretically I see no reason why a double cardan CV joint can't be used with a slip yoke
thats what the former owner of mine did. i have vibration at the sye, but at this point unsure exactly is causing it. slop etc. dave
um, you can't have both a slip yoke eliminator and a slip yoke. I assume you have a slip yoke? pictures?
Although I"m by no means an expert, and I have never seen it done, theoretically I see no reason why a double cardan CV joint can't be used with a slip yoke.
As I understand it (and I could be wrong), a CV joint has a certain amount of flex in it (two joints together instead of one). you just can't have that flex right next to the slip joint.
Or it will play crack the whip as it goes skip to my loo!
