maint required light
The other day my maint required light came on a few miles after it turned 120k miles so I suspected it might be an automatic service reminder. I called a Jeep dealer and they confirmed this as the likely cause. Now I need to know how and where to cancel out the light. It is a 92 comanche.
isnt that unit the timer for the o2 sensor Thast is what i thought it was and i have unplugged mine years ago :brows: just another question didnt they have the obd-I on board the 92 MJ's and did this provide some indcations for service required :dunno:
I have a 91 and the 91 and later are the ODB I, I happen to have an OEM Chrysler code reader that I got fairly cheap on Ebay that I used to reset the MAINT REQ light. If all you want to do is make the light go off I would remove the bulb as Pete suggested. For me that tool has been great for troubleshooting a host of other problems much easier. Right now that reader has helped me isolate certain issues in my ignition system.
When I put in the JC bored out throttle body assembly my gas mileage and perfromance decreased significantly I ran some diagnostics and found my TPS was at .75 OHMs instead of the 1-4 OHM range accross the throttle (yes I am too lazy to run an OHM meter). Not what I would call an absolute necessity of a tool but it sure has come in handy for me.
Anyone know if they may have placed the OBD1 in some of the later made model year 1990 MJ's?
Anyone have pictures showcasing the difference between the two reader ports? OBD1 and the one that requires a $3000 reader from Snap-on?
the easiest way to make this determination is to look for the ECU.
Chryco ECU's were under the hood, renix ECU's are under the dash, drivers side, right above the accelerator, big silver looking metal box.
