1tonMJ Posted August 8, 2011 Share Posted August 8, 2011 88 MJ. 2wd. No lift, I got 30's that *might* fit with no trimming, but I suspect I will have to trim 1-2" of fender. Any one know the exact measurement of metal i have to remove? I would like to cut once, if possible. ANNNND When all is said and done, how do I measure for new flares? Link to comment Share on other sites More sharing options...
mnkyboy Posted August 8, 2011 Share Posted August 8, 2011 Shouldnt need any trimming I had 30x9.50-15s on 3.75" BS wheels on my XJ with no trimming,they would have fit even better on OEM wheels. If it does rub just put a 1- 1.75 coil spacer in to level the truck out Link to comment Share on other sites More sharing options...
Rebelfish99 Posted August 8, 2011 Share Posted August 8, 2011 Shouldnt need any trimming I had 30x9.50-15s on 3.75" BS wheels on my XJ with no trimming,they would have fit even better on OEM wheels. If it does rub just put a 1- 1.75 coil spacer in to level the truck out Same, I just mounted 30x9.50sx15 on stock jeep wheels with no trimming required on my MJ. Link to comment Share on other sites More sharing options...
Garvin Posted August 8, 2011 Share Posted August 8, 2011 When I picked up my '86, it had 31x9.5R15's on it with no lift on stock rims. The tires cleared the fenders and bed fine, it just rubbed on the lower control arms at full lock. Link to comment Share on other sites More sharing options...
1tonMJ Posted August 8, 2011 Author Share Posted August 8, 2011 OK. I set them up next to the old wheels, they look like they hit the fender, but I understand that they will pick up the axle itself a little bit. Just trying to get my ducks in a row. :wrench: Link to comment Share on other sites More sharing options...
Pete M Posted August 8, 2011 Share Posted August 8, 2011 my 88 back when she was 2wd running 30x9.5s on stock rims. no rubbing whatsoever. :thumbsup: Link to comment Share on other sites More sharing options...
pamike Posted August 8, 2011 Share Posted August 8, 2011 i ran 31x10.50's on my 88 4x4 with stock wheels for a while with no problems Link to comment Share on other sites More sharing options...
1990 Pioneer 4x4 Posted August 9, 2011 Share Posted August 9, 2011 depends on what 30" tires you're running. I had 30" BFG AT's for years with no clearance issues, as soon as i changed to the 30" BFG Mt's, the tires started to make contact. Link to comment Share on other sites More sharing options...
Pete M Posted August 9, 2011 Share Posted August 9, 2011 interesting. what rims? where was the contact? Link to comment Share on other sites More sharing options...
1990 Pioneer 4x4 Posted August 10, 2011 Share Posted August 10, 2011 Amercian Racing wheels - Outlaw 1. They rub on the lower front fender when compressed and turning. Link to comment Share on other sites More sharing options...
Pete M Posted August 10, 2011 Share Posted August 10, 2011 yup. that is certainly possible with aftermarket rims. Link to comment Share on other sites More sharing options...
jimoshel Posted August 10, 2011 Share Posted August 10, 2011 I have a '86 Long box, 4WD with 31:10.50, no lift and they don't rub on anything. I don't trail it, just normal road driving. Don't know if the rims are stock or after market. If I think about it, I'll check tomorrow. Correction; Checked. It has 2" hangers in the rear and 1 1/2 inch spacers on the front coils. Just got to dern many. Can't keep 'em all straight. :thwak: Link to comment Share on other sites More sharing options...
