dfreeman616 Posted July 25, 2011 Share Posted July 25, 2011 you're proportioning valve rod is on wrong, it should be going vertical not horizontal from the driver side of the diff cover Link to comment Share on other sites More sharing options...
MancheKid86 Posted July 25, 2011 Author Share Posted July 25, 2011 you're proportioning valve rod is on wrong, it should be going vertical not horizontal from the driver side of the diff cover I'm aware of this :thumbsup: just not too concerned, will get around to changing it up, and i know i know :needpics: here ya are Link to comment Share on other sites More sharing options...
Comanche County Posted July 25, 2011 Share Posted July 25, 2011 That J10 is a 3/4 ton J20. The D44HD front and matching D60 rear are good swap material even if the front is a pre-'80 pass. side drop. They are not as wide as most trucks. Swap a D300 x-fer onto the back of a 4x4 AW4, stick those axles on... :wrench: Yup, those things would have rode home with me! Now go back and get em! :wrench: Currently have 3 D44s sitting out back,,,,just need more MJs to put them in! Good job on your MJ, its coming along nicely! :cheers: Link to comment Share on other sites More sharing options...
MancheKid86 Posted July 29, 2011 Author Share Posted July 29, 2011 time for an oil change :wrench: the parts off with the old doesnt look too bad inside new k&n oil filter all back together, threw a new valve cover gasket on as well blower stopped working, pulled the controls to find this, replaced the box and spliced the wires in. also wired in a cigar lighter all together :D then, as i was backing out of my drive way for a late night 7-11 run, this happened. :roll: cop who happened to roll up beside me for gas stood there scratching their head trying to figure out what happened :dunno: , i guess thats what i get for leaving jugs full of oil right beside the comanche :thumbsup: jeep on Link to comment Share on other sites More sharing options...
MancheKid86 Posted August 16, 2011 Author Share Posted August 16, 2011 update, starter relay and ignition coil went on me, replaced them with 4.0L parts and it fired right up :D took my little truck wheeling yesterday, came close to going over the edge, so i kicked the GF out, and thankfully didnt go over the edge :D pic from the night before, our starting location after a 20 min treck through the bush, we made it onto.... a new highway being built XD oops, we came from the other side of this fence. and this is where i almost lost it, 4th run up, with 1st gear screaming and i made it, only shy of one pair of under garments me and my comanche panoramic view of where we ended up, I'm on the far right, ended up turning around and going back the way we came. click this link for full sized pic ^^^^^^^ there was more to take pics of, but my co-pilot was a little shaken up after our first hill climb :shake: Link to comment Share on other sites More sharing options...
btm24 Posted August 20, 2011 Share Posted August 20, 2011 you know if you get a ZJ tir rode you won't do it again :yes: they are ALOT stronger, and if you paint it it will make it look 10 times better :) Brandon Link to comment Share on other sites More sharing options...
MancheKid86 Posted August 30, 2011 Author Share Posted August 30, 2011 you know if you get a ZJ tir rode you won't do it again :yes: they are ALOT stronger, and if you paint it it will make it look 10 times better :) Brandon funny you should mention that went to PnP a week and a bit ago got a V8 ZJ tie rod for $9.49 :thumbsup: installed then, did a bit of wheeling to test it out, muuuuch better, improved steering, less delay from the wheel as well :yes: MJ earning its keep, scored a 62" tv for under $200 :shake: battery died, so... i checked the cables to see if there was a problem, I'm thinking so :oops: the culprit all done, new wires and terminals turns out, that wasnt the only problem, seems like my alternator got fried, so... you know what that means, out with the old, in with the heavy duty old 65 amp alternator vs. new 115 amp alternator. installed while replacing the alternator, i decided to clean part of my engine bay, found rust under the battery tray! out comes the rust converter all converted and all back together, installing factory window "covers" just slide em in, and take a screw driver and push theese 3 clips in per door, and re assemble all done not so random, random comanche (been staring at it for years! decided to take a trip and visit it :P ) more to come as always :D *edit* also, did i forget to mention, my girlfriend helped me work on the truck!!! :clapping: :yes: :wrench: :D Link to comment Share on other sites More sharing options...
MancheKid86 Posted September 2, 2011 Author Share Posted September 2, 2011 update, chewed through 2 serpentine belts doing light driving in the last 2 days :fs1: drove it home one night, then the next time i couldnt make it home, so i went to my gf's house where i fixed it after i got a ride into the next town to get parts :D my new alternator is the culprit, the pulley on it didnt line up with the tensioner or power steering pump, its all fixed now but not before it tore my dayco poly rib belt to shreds =[ i had to remove the stock alternator spacer and spin it around, (on the right where the bolt is) and on the left i had to put 2 washers in to keep every thing nice and tight. 3 washers in the bottom behind the 90 degree flange ( same width as the 2 uptop) and then 3 washers behind the alternator pulley itself (they were such a tight fit i had to drive them past the threads) everything is lined up perfectly now :jump: more to come, here's a pic of a comanche that rolled up to my work. 1989 renix 4.0l blue, he is the second owner of this comanche and has owned it for 20 years now :thumbsup: Link to comment Share on other sites More sharing options...
MancheKid86 Posted October 1, 2011 Author Share Posted October 1, 2011 had a fender bender, hydroplaned into the guy. so out comes the tree to fix the bumper :D i pulled the dent out of the fender after as well then i went to pnp to get parts for my blue comanche i seen there was a comanche in stock so i went thru it black 1987 6 cyl 4wd, dana 35/30 combo propane conversion. it had alot of goodies :D more to come :thumbsup: Link to comment Share on other sites More sharing options...
MancheKid86 Posted October 28, 2011 Author Share Posted October 28, 2011 not much to update, havent installed the cargo-light, will do that once i get old rusty on the road, that way i can take this one off the road, gut it, and resto, pics :D shes been my weekend wheeler, found a stump :roll: then after a while... i got stuck in the most ridiculous spot... had to walk out and get er tugged out the next day, thats when i decided i really needed 4wd, workin on brining old rusty back on the road i got parts in the mail :banana: do you know how hard these are to get in my neck of the woods? got them shipped up from a fellow bcjeepclub member. off with the old on with being street legal once again :D me and my comanche :D took her for a spin up to a nice spot to eat some grub with the woman and last but not least, the view still waiting on my neighbor to pick up the sandblaster, have the medium waiting to go to get on with the rust repair, more to come jeep on Link to comment Share on other sites More sharing options...
Thunderbear Posted October 30, 2011 Share Posted October 30, 2011 You're not actually going to leave the winch bumper at the pick and pull are you? That would be a hell of a score. Link to comment Share on other sites More sharing options...
scobad Posted November 1, 2011 Share Posted November 1, 2011 I agree - I want that BUMPER !!! Link to comment Share on other sites More sharing options...
MancheKid86 Posted December 3, 2011 Author Share Posted December 3, 2011 You're not actually going to leave the winch bumper at the pick and pull are you? That would be a hell of a score. if i had the extra cash, i would have done it. right now I'm in college to become an Aircraft Maintenance Engineer - M so cash is more than a little tight, battery died, miss firing, brakes are shot o_O need an oil change. :( well, i got a new battery, at a SMOKING DEAL an optima yellow top, list price $600, my price $200 :D new spark plugs, hmmm i wonder why i had a miss fire :dunno: new meats, on my old rims, stoked all my rims are the same color, just need to find my beauty rings :D now the bad, winter time hit, i had bad tires, end result more too come, havent updated old rusty because my neighbor hasnt gotten the sandblaster, i have the medium and am ready to blast the frame, but that will have to wait till a later date. jeep on Link to comment Share on other sites More sharing options...
shawn Posted December 3, 2011 Share Posted December 3, 2011 you will regret not getting that bumper. ----- also the zj pitman arm might come in handy at some point too. Link to comment Share on other sites More sharing options...
MancheKid86 Posted December 10, 2011 Author Share Posted December 10, 2011 i have another bumper that can hold a winch too, just havent found time to fab it on :yes: bout time for an oil change decided it was a good idea to use my neighbors driveway :rotf: besides old rusty needs some company some times XD only the best for oil filters, K&N performance gold :D took my beauty rings out of the shed and decided to polish em and mounted more to come :wrench: Link to comment Share on other sites More sharing options...
MancheKid86 Posted February 5, 2012 Author Share Posted February 5, 2012 SOLD Link to comment Share on other sites More sharing options...
btm24 Posted February 5, 2012 Share Posted February 5, 2012 :( Brandon Link to comment Share on other sites More sharing options...
MancheKid86 Posted February 5, 2012 Author Share Posted February 5, 2012 :( Brandon viewtopic.php?f=3&t=34254 :thumbsup: Link to comment Share on other sites More sharing options...
btm24 Posted February 6, 2012 Share Posted February 6, 2012 :clapping: Brandon Link to comment Share on other sites More sharing options...
Dirteatr717 Posted February 28, 2012 Share Posted February 28, 2012 So where's the pics and what not of the new heaps! Link to comment Share on other sites More sharing options...
