sinned96 Posted December 27, 2006 Share Posted December 27, 2006 A passenger rolled my door window down too far and now it won't roll back up. I know the regulator was stripped so I never rolled it all they way down. Its dang cold in the morning. How do I go about getting it back up? I got the door panel off and tried lifting it by hand while turning the crank but it won't budge. Anyone have a good passenger side regulator that they want to part with? Link to comment Share on other sites More sharing options...
jbhill Posted December 27, 2006 Share Posted December 27, 2006 check w/ the parts store to see if they have one in stock. shouldnt be to expensive. alldata shows 62 bux for a new dealer one and 1.3 hours to replace it so it shouldnt be that hard, ive just never taken one out. ull prob be better off takin it out (tape the glass up so it doesnt fall down on you) and either fixin yours or puttin in a new one. Link to comment Share on other sites More sharing options...
sinned96 Posted December 27, 2006 Author Share Posted December 27, 2006 right now i wish i could get the damn thing to just go up Link to comment Share on other sites More sharing options...
Wildman Posted December 28, 2006 Share Posted December 28, 2006 simmed96 - If you have the door panel off, you should be able to push the glass up, unless the regulator is really @#**%. If the glass won't move, you can try to take the nut/stud off the arm, and push the glass up, but then you will need to tape the glass in place or it will just fall back down into the door and.....well. If no one else jumps in on this, PM me and I can get one off of a XJ I'm parting out. jbhill - Where did you find a replacement regulator???? I and others have been looking all over the place, others even checked out the dealers. It just don't exist. I had to take one out of the junk XJ to fix one of my regulators. Link to comment Share on other sites More sharing options...
Kenosha Warrior Posted December 28, 2006 Share Posted December 28, 2006 simmed96 - If you have the door panel off, you should be able to push the glass up, unless the regulator is really @#**%. If the glass won't move, you can try to take the nut/stud off the arm, and push the glass up, but then you will need to tape the glass in place or it will just fall back down into the door and.....well. If no one else jumps in on this, PM me and I can get one off of a XJ I'm parting out. jbhill - Where did you find a replacement regulator???? I and others have been looking all over the place, others even checked out the dealers. It just don't exist. I had to take one out of the junk XJ to fix one of my regulators. my pass window on an old xj would just drop and dissapear if it was put down more than 3/4 of the way, so I stuck a piece of 2x4 in the door so the window will just stop on the wood, and not go past 3/4 :) Link to comment Share on other sites More sharing options...
sinned96 Posted December 28, 2006 Author Share Posted December 28, 2006 well the regulator is toast. I ended up unbolting the glass from the mount and stuck a piece of wood inside the door to hold the window in the up position for now till i get the new regulator. Kind of ghetto but and least i won't freeze on the way to work now. Link to comment Share on other sites More sharing options...
jeepthing07 Posted December 28, 2006 Share Posted December 28, 2006 my passenger window is the same way. the dude that owned it before me put a hose clamp on something inside the door so it won't roll all the way down. sticks up about 2 inches and you can grab the glass and pull up while cranking and it rolls back up. Link to comment Share on other sites More sharing options...
mjeff87 Posted December 28, 2006 Share Posted December 28, 2006 It's good to hear that I'm not the only redneck on here with a piece of 2X4 inside the passenger door :D I'll get around to replacing the regulator some day, but for now, the wood works...should be in a FAQ sticky ;) Jeff Link to comment Share on other sites More sharing options...
88swampedmj Posted December 28, 2006 Share Posted December 28, 2006 just take your door panel off for a sec.. push up as you roll it up and itll go.. i stripped my interior haha my window does the same.. Link to comment Share on other sites More sharing options...
86FUBAR Posted December 29, 2006 Share Posted December 29, 2006 ya mine did the same thing ,n all i did was use a 2x4 and glued it to the in side of the door to stop it. needless to say i have stacked bout 2.5in to it over the past 6 years and still have no plans of fixin it , i don't sit over their. Link to comment Share on other sites More sharing options...
