I've seem to be getting about 75-80 psi oil pressure lately... It has been like this ever since I got the truck. I plan on doing an oil change, and with that oil change I will be dropping the oil pan to see what condition the oil screen is in..
If the screen is in pretty good shape, what else could be the problem?
Thanks
If the sending unit is messed up any guage cluster will read the same.
You need to pull the sending unit out and hook a guage straight to the engine to see for sure what the pressure is.
If the oil pickup screen is clogged you would have LOW oil pressure.Replace the sending unit first and/or check pressure with a mechanical guage.
mine reads the same until the engine warms up then drops midway between 40 - 50 at idle -- been that way for the 13 yrs I've owned her -- factory installed guage cluster jamminz.gif
I got a new sending unit not long ago and haven't had time to install it. I will install it today hopefully after painting the kitchen for my mom and see if it changes anything.
IS this the oil pressure switch? I can not make it come off ABOVE the hose... But it turns below the hose... Is that correct?
That's an oil pressure sender, but what's with the tee fitting and rubber hose just below it?
What year MJ and what engine are we talking about?
The hose coming out of the tee must lead to a oil cooler or an auxiliary oil filter. The oil sending unit should thread out of the tee. You need to hold the lower tee and thread the sending unit out. I have a picture of my setup, the tee goes to a mechanical gauge and the sending unit goes to the dash light. My 2.5 runs high oil pressure as well, ~70-80 when cold, ~30-50 warm.
The hose on mine goes to I guess the vacuum "bubble" behind the front bumper... But I've tried to hold the T and screw the unit out but it won't budge..
My grandfather did say he had amsoil installed on it... When I got the truck I never could find the amsoil system, but I guess I found it, right? haha
Could be an accumulator. Racers use them for pressurized oil in their system on startup to reduce bearing wear. Though pics would be very helpful to verify what it is.
This is what the hose from the 'T' fitting goes to...
Can't really see, but this is up close,
And this is where the other hose leads to...
Is it amsoil?
Got it installed but now it reads way passed 80... 180 degrees from when engine is shut off
You probably got the one for a vehicle with idiot lights rather than the one for gauges.
Maybe when you ask for the new one make sure you say sending unit instead of oil switch. If they ask what year make model kinda thing, find someone with same year truck that has oil gauge from the factory and tell the computer jockey at the counter thats what you have. The oil switch does just like it sounds, closes contacts or opens them like a switch (for the idiot light style), but the oil sender is more of a reostat that transmits voltage or grounding resistance depending on the position of the internals in the sender (via various presures) kinda like a fuel sender. If your gauge pegs when you turn your key you most likely have a switch installed instead of a sender.
Oh and that remote thingy could be a few things. Maybe a water seperater or an extra oil filter.... My dad runs remote oil filters with built in water seperators that look similar to that.
I looked on rockauto for a sender, but they didn't have one.. Anyone know where I could get one it's a 87 jeep comanche 2.5L.. It goes all the way to the right (flat line) when I crank the car up and it stays in that position.
And I emailed my grandfather about the filter and it is the amsoil system. I'm just not sure how to remove it.. lol
P.S. thanks for everyone's help so far!
Yes, they do.
http://www.rockauto.com/catalog/x,carco ... ttype,4588
Scroll down to the next-to-last item.
ACDELCO Part # 15591103 More Info
SENSOR,F/PMP SW & ENG OIL PRESS GA
