comancheman Posted December 17, 2006 Share Posted December 17, 2006 ok so ive got a 90 comanche with the vac disconnect d/30 and an 89 cherokee with the non vac disconnect d/30. one of these is goin on a two wheel drive comanche once i get the tcase in. which ones is better? id like to keep both but i need all vehicles to roll inorder to have th jy take them away. I'm thinkin the cherokee axle is better just because theres less stuff to break but i may be wrong. any opinions? Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted December 17, 2006 Share Posted December 17, 2006 The NON disco is a margoinally stronger case and the one I would choose. The disco does have its atributes as well. You only need to find a post 96 D30 and swap in those shafts to get 760 joints for the strongest D30 the factory had to offer!!! CW Link to comment Share on other sites More sharing options...
Pete M Posted December 17, 2006 Share Posted December 17, 2006 What are their gear ratios? Link to comment Share on other sites More sharing options...
jage Posted December 17, 2006 Share Posted December 17, 2006 Yeah, disco is good if you want to cable disconnect and run an ezlocker or something. Otherwise I'd say go with whichever is in better shape. Link to comment Share on other sites More sharing options...
comancheman Posted December 17, 2006 Author Share Posted December 17, 2006 not sure, but if this helps there both in front of the 4.0 with the aw4 tranny. any chance in these having the same ratio as the d44 in the 2wd truck also a 4.0 with the aw4? Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted December 17, 2006 Share Posted December 17, 2006 There is a VERY good chance thet they are ALL 3:55's!!! Thats the norm for AW4 and a 4.0!! CW Link to comment Share on other sites More sharing options...
comancheman Posted December 17, 2006 Author Share Posted December 17, 2006 nice Link to comment Share on other sites More sharing options...
Southen Crawlin Posted December 17, 2006 Share Posted December 17, 2006 well after a fair bit of research id choose the vac disco one if there werent hard core rock crawling plans. reason: no one likes them so parts are everywhere, the vacume can be replaced by the allways reliable cable, it can be lincoln locked and still drove on the street like ya didnt have a locker due to the disconect. now also consider that if your gonna hard core rock crawl then the front steering on street won't be of much concern since it probly won't see much or anny street driving at all. so the extra strength of non disco axles is the better choice. Link to comment Share on other sites More sharing options...
Eagle Posted December 17, 2006 Share Posted December 17, 2006 Another argument in favor of the disco axle is the right side control arm mounts. On the non-disco, the UCA mounts to a sheet metal bracket that's welded to the axle tube. Fine for street use, but lots of heavy off-road use can twist that bracket into a pretzel. The right side UCA on the disco axle mounts to an ear that's part of the cast disconnect housing. It's MUCH stronger. Link to comment Share on other sites More sharing options...
Pete M Posted December 17, 2006 Share Posted December 17, 2006 For me, either one is fine since they both need to be upgraded to shafts that run the larger U-joints. http://www.madxj.com/MADXJ/technical/te ... dSeals.htm Link to comment Share on other sites More sharing options...
Oizarod115 Posted December 17, 2006 Share Posted December 17, 2006 actually... if it had a factory D44 it might have lower gears... could have towing gears or something... i know XJ towpackage had 3.73s. Link to comment Share on other sites More sharing options...
Twisty Posted December 17, 2006 Share Posted December 17, 2006 mine has a d44, and 3.54 gears. i don't know what i should do in the up-coming year. id like to keep the disco axle because i like the idea of a lincoln locker to save money on lockers, but i want a strong axle capable of 35's. i am a VERY light driver and never spin the tires, so I'm hoping that with upgraded joints i will be all set. is there anyway to get the 760x joints into a disco axle, and retain the disco part of it? i read the link that pete posted, and I'm a little confused about what he reaplaced. Link to comment Share on other sites More sharing options...
Oizarod115 Posted December 17, 2006 Share Posted December 17, 2006 yeah... 1995 YJ shafts are D30 disconnect with 297x or w/e it is that the big ones are u-joints Link to comment Share on other sites More sharing options...
Twisty Posted December 17, 2006 Share Posted December 17, 2006 Oizarod115...thats sweet! we have a 1995 yj and i went out and looked, and it DOES have a disco! I'm so excited. (no, I'm not going to steal those). sorry for kind of hi-jacking your thread comancheman :waving: Link to comment Share on other sites More sharing options...
Oizarod115 Posted December 17, 2006 Share Posted December 17, 2006 yeah. pete or someone let me in on that tid bit bout a week ago ;) welcome Link to comment Share on other sites More sharing options...
comancheman Posted December 17, 2006 Author Share Posted December 17, 2006 so if i went with the vac disco id probably put on the posi lock just to be safe. now if i was to lincoln lock the front end it wouldnt make a difference on the road because of the disconnect. but i will lose the option of being in 4wd and having an open front end, right? Link to comment Share on other sites More sharing options...
Pete M Posted December 17, 2006 Share Posted December 17, 2006 Yup. Trying to run on the street in 3 wheel drive is ill advised. The biggest issue I see here is that you want to run 35" tires on the little 260 U-joints. That won't last long. Link to comment Share on other sites More sharing options...
comancheman Posted December 17, 2006 Author Share Posted December 17, 2006 if i upgraded to the later model shafts would 35's still be an issue, cause theres plenty of jeeps around here that i can grab parts off Link to comment Share on other sites More sharing options...
Pete M Posted December 17, 2006 Share Posted December 17, 2006 35" tires can break parts in Dana 44s, let alone Dana 30s. Nothing is indestructible. 35 inches is a lot of tire and the Dana 30 is a small axle, but if you get shafts that run 297 or 760 'joints and leave the front open it should be fine. Of course, longevity is also dependent on the tires you get, the terrain you travel, and how much you like the skinny pedal. If you want to run big tires, expect to pay for it somewhere. Link to comment Share on other sites More sharing options...
comancheman Posted December 17, 2006 Author Share Posted December 17, 2006 alright guys thanks for the help but when it came down to it i went with the vac dico just because i didnt feel like pullin the non disco out of the cherokee. Link to comment Share on other sites More sharing options...
Pete M Posted December 17, 2006 Share Posted December 17, 2006 laziness wins again! :cheers: Link to comment Share on other sites More sharing options...
Oizarod115 Posted December 17, 2006 Share Posted December 17, 2006 haha, thats the one i prolly wouldve chosen too man. but i do have one question to jack this thread.. since the topic is over and its still about vacuum d/30s. is there anything special that has to be done in order to pull the disconnect shaft in a disco-30? or do you just yank the shaft exactly how you yank the shaft on the short side? if the question isnt clear let me know ill try to ask it better. -tahnks nick Link to comment Share on other sites More sharing options...
comancheman Posted December 17, 2006 Author Share Posted December 17, 2006 hey, after pullin the tranny out of the cherokee i didnt feel like doin an axle the same day. dad says ones gotta go before another can come so by by non disco Link to comment Share on other sites More sharing options...
JOMJ87 Posted December 18, 2006 Share Posted December 18, 2006 haha, thats the one i prolly wouldve chosen too man. but i do have one question to jack this thread.. since the topic is over and its still about vacuum d/30s. is there anything special that has to be done in order to pull the disconnect shaft in a disco-30? or do you just yank the shaft exactly how you yank the shaft on the short side? if the question isnt clear let me know ill try to ask it better. -tahnks nick So are oyu asking how to pull the axle shafts out of the case. If so you have to remove the disco controls on the axle and then take you fingers and slide the center piece out through the tube after the outer shgaft is gone of course and the short side is the same as removing the outer shaft on the long side. Hope this helps. Cole Link to comment Share on other sites More sharing options...
Oizarod115 Posted December 18, 2006 Share Posted December 18, 2006 so i undo all the vacuum goodies, and pull the vacuum cover off the axle, then do al the hub-stuf and pull the axle shaft, then slide the sleeve thingy out the same way as the axleshaft? or out the disconnect housing? then the inner axle stays? or does it pull out too? I'm just changin u-joints. so do i need to pull the innermost shaft in order to run just the stub-shaft? cuase i can't change ujoints myself. the shop we took the left side to spent the better part of an hour getting the b*@$£ out. (origional spicer joints 17yo) Link to comment Share on other sites More sharing options...
