btm24 Posted February 26, 2011 Posted February 26, 2011 So with in the week I'm going to try and install my cargo light. Any do's and donts I need to know about? Are there any tips any body would share from when you did this? Thanks Brandon
MJCARENA Posted February 26, 2011 Posted February 26, 2011 Measure twice and cut once. Sorry, not much help.
fiatslug87 Posted February 27, 2011 Posted February 27, 2011 http://comancheclub.com/forums/viewtopic.php?f=2&t=12371&hilit=Cargo+light
glundblad Posted February 27, 2011 Posted February 27, 2011 So your truck didnt come with a factory cargo light but you are installing one? You have more courage than I ever will. Good luck. :cheers:
flint54 Posted February 27, 2011 Posted February 27, 2011 Courage, plus the incredibly good fortune to actually find one! I remember when I had my interior gutted (and regret now not making any images) and looking at that spot on the shell wondering if I could really pull that (drill) trigger. Speaking of cargo lights, I'm curious if anyone has ever contacted Chrysler to learn if there's a chance of finding build records from the Toledo assembly plant. Neat to know how many trucks ever got this light, and, who the supplier was.
Akula69 Posted February 27, 2011 Posted February 27, 2011 Installed one on Junior just last weekend, and had installed the one on the '89 last August. After I measured and found the center of the window (and the correct height) I put a thin coating of silcone gasket sealer on the back of the rubber seal for insurance. I did not seal between the plastic housing and the rubber seal as the screws should pull it tight enough to keep water out. Neither have leaked yet.
xjrev10 Posted February 28, 2011 Posted February 28, 2011 So your truck didnt come with a factory cargo light but you are installing one? You have more courage than I ever will. Good luck. :cheers: agreed
ParadiseMJ Posted February 28, 2011 Posted February 28, 2011 I wanted to go with the cargo light/3rd brake light combo off of a Ford Ranger. Just settled for the 3rd brake light alone which I got the light and connectors and about 2 ft, of wire off an XJ. Very easy, one wire off the trailer wiring and a ground. My mantra is more like measure 5 or 6 times, cut once. It can leave quite a gap in just the wrong place if it's off. My under dash wiring has a plug for the cargo light switch and as far as I know it's the skinny pink wire up along the b-pillar. Pictures please.
Cajun Posted March 1, 2011 Posted March 1, 2011 I WOULD HESITATE ON CUTTING THE METAL. I MOUNTED A FOG LIGHT ON TO THE BED AND REVERSED IT WHERE IT WAS HIDDEN IN THE CORNER. WIRE WAS EASY TO RUN TO THE BATTERY AND GROUND, AND I PUT A PUSH/PULL SWITCH ON THE LOWER PART OF THE DASH. IT WORKS JUST FINE AND YOU KEEP THE INTEGRITY OF THE CAB. IT'S A CHEAP SETUP...-CAJUN
