jeepjunkee Posted February 21, 2011 Share Posted February 21, 2011 Brake booster with master cylinder. Nice upgrade on the older xj or mj if you have larger tires or now have rear disc brakes from a 8.8 swap. $100 shipped Here is a nice write-up http://www.madxj.com/MADXJ/technical/te ... pgrade.htm Link to comment Share on other sites More sharing options...
jeepdoggydogB Posted February 26, 2011 Share Posted February 26, 2011 Hello, At the price of $100 I am get that these are used, but are they tested to work? Do you have any pics and do you take PAYPAL? Thanks, Joe Link to comment Share on other sites More sharing options...
jeepjunkee Posted February 27, 2011 Author Share Posted February 27, 2011 I bought the xj with no motor trans but when moving the vehicle the brakes still felt good and stopped it fine. I do accept paypal i will get pictures tues. Link to comment Share on other sites More sharing options...
jeepjunkee Posted March 8, 2011 Author Share Posted March 8, 2011 No takers? New price $85 shipped can get pics if interested Link to comment Share on other sites More sharing options...
jeepjunkee Posted March 11, 2011 Author Share Posted March 11, 2011 Image Not Found Image Not Found Image Not Found Image Not Found Link to comment Share on other sites More sharing options...
Automan2164 Posted March 11, 2011 Share Posted March 11, 2011 Interested. I'm at work, and can't look it up right now, but is this the bolt in year? Rob L. Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 11, 2011 Share Posted March 11, 2011 Where's the aluminum spacer plate? Link to comment Share on other sites More sharing options...
jeepjunkee Posted March 12, 2011 Author Share Posted March 12, 2011 Interested. I'm at work, and can't look it up right now, but is this the bolt in year? Rob L. From what i read on madxj.com it should be a bolt in job. The link may be down but just go to madxj.com and read all about it. Where's the aluminum spacer plate? I don't recall a spacer. Maybe i overlooked it but i rememeber just the white gasket being against the firewall. :dunno: Link to comment Share on other sites More sharing options...
Automan2164 Posted March 12, 2011 Share Posted March 12, 2011 Might have found one local. Going to have to bow out. Rob L. Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 12, 2011 Share Posted March 12, 2011 I don't recall a spacer. Maybe i overlooked it but i rememeber just the white gasket being against the firewall. :dunno: If it came from a 95 XJ it had the alum spacer. No exceptions. :cheers: Link to comment Share on other sites More sharing options...
btm24 Posted March 12, 2011 Share Posted March 12, 2011 The aluminum spacer is behind the white part on the back. Brandon Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 12, 2011 Share Posted March 12, 2011 No it's not. Link to comment Share on other sites More sharing options...
btm24 Posted March 12, 2011 Share Posted March 12, 2011 Are you sure? I'm sure that thats where it is on mine. Ill check tomarrow when I have to pull it out of the shed any ways. Brandon Link to comment Share on other sites More sharing options...
jeepjunkee Posted March 12, 2011 Author Share Posted March 12, 2011 No it's not. Maybe you could enlighten me with a picture of this aluminum spacer. But anyway i do not have this so called spacer. If it was on the firewall i didnt get it. Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 12, 2011 Share Posted March 12, 2011 Are you sure? I'm sure that thats where it is on mine. Ill check tomarrow when I have to pull it out of the shed any ways. Brandon I thought you meant it was shown in the seller's pics. You are correct, it's between the foam gasket and the firewall. No it's not. Maybe you could enlighten me with a picture of this aluminum spacer. But anyway i do not have this so called spacer. If it was on the firewall i didnt get it. The "so-called" spacer is on the firewall. My 95 booster/master is installed so no pic. Maybe Brandon can shoot you a pic. Link to comment Share on other sites More sharing options...
maddzz1 Posted March 12, 2011 Share Posted March 12, 2011 I have also done this upgrade. If you peel back that white foam thing a little you will see the aluminum spacer. Link to comment Share on other sites More sharing options...
btm24 Posted March 12, 2011 Share Posted March 12, 2011 Here you go: Thats it right? Thats on a 95 XJ booster Brandon Link to comment Share on other sites More sharing options...
JeepcoMJ Posted March 12, 2011 Share Posted March 12, 2011 every one I've ever had the spacer is between the gasket and the booster, not the gasket and the firewall. that's '95 on up. the difference in the '95, from my understanding, is the rod itself is proper to use in our years. Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 13, 2011 Share Posted March 13, 2011 Here you go: Thats it right? Thats on a 95 XJ booster Brandon You're right. :thumbsup: I did this swap so long ago I'd forgotten. I looked it up in the 95-96 parts manual and the spacer is not even listed. I guess they never have to be replaced. :yes: The gasket has a part number though. Link to comment Share on other sites More sharing options...
jeepjunkee Posted March 23, 2011 Author Share Posted March 23, 2011 Bump Link to comment Share on other sites More sharing options...
Archived
