i need some suggestions on a good set of ball joints....
I'm sooooo sick of replacing these cheap a$$ advanced auto ones
i don't even wheel hard and ive changed 2 new ones in the last 2 months....please help!!!!!
only 1 word: MOOG
youl pay but you won't change no more
this is the one ! MOOG !! i have been working on autos etc for 30 some years -moog is my first tier ! for grease conklin rhino -this combo works very well --stay way from the white box parts -made in china by little old lady !
i have oebrd from advance auto on now...theyre crappy
20 bucks or so a end
draglink was $60
you get what u pay for
their still under warranty.....sooooo
i HAVE to get my new ones from Advance ...theyll credit me for the old broken ones...
so thats my options....
which is the best ones from Advance?
i just went out this morning and got some stuff to upgrade to solve this problem once and for all
draglink
tie rods steering damper
all moog
i needed some gloves...lol....and i got the heavier grease...i just thought it would be better
project went sooth as silk...thank god
i got done and noticed my end links.....remember this great idea i had about 6 months ago??
:shake: :shake:
anyways, after seeing the grease was pouring out of the thing and the top bushing was warped real bad, i replaced it with one of my sterling stinger specials...
these work great believe it or not...I'm currently making ones out of 5/8 cold rolled steel at work....there gonna be crazy strong.....
ok...."tell the captain were out of sugar"--:Cabin Boy....lolololol
look at your pic
it goes the same way that's on there
the big end goes on the shock with a zap-strap to hold it
and the other end slips over the the tip of the extending rod ( there is a groove for it in the boot)
maybe the boot is to long or.......
the shock is to long !!!
with all the parts you just changed I'm assuming its a steering damper
do you reach full steering on each side without the damper reaching full run ??
it might be just a faulty adjusment as you might need to move the damper
google this :
jeep steering damper bracket
i tought you were using one of those and not the original setting
I never reuse the original setting
reason: I always use beefier damper and then they don't fit
edit: your damper should have come with some brackets when you ordered it?
