$500 MJ's header panel What year front end is this?
The older 8-slot grilles used the older header and headlight trim. The chrome trim strip across the top was three separate pieces, one for the center and two curved pieces over the headlights. In 1990 (I think) Chrysler revised/simplified it so the upper trim band was an integral part of the grille and the headlight bezels. The newer style takes a different header panel, but from ten feet away they look the same.
Factory grills and associated part numbers:
5500 0153 Black, Cherokee, Comanche, 1987 (Paint as Required)
5500 2229 Chrome/Black, Cherokee, Comanche, 1987
5501 8658 Charcoal, Cherokee "Limited", 1987
5501 8657 Classic Black, Cherokee "Limited", 1987
5501 8656 Grenadine, Cherokee "Limited", 1987
5501 9666 Grenadine, Cherokee "Limited" 1988
5501 3144 Argent/Black, Cherokee, Comanche, 1988-90
5502 0262 Black/Colorado Red, Cherokee, Comanche, 1988-89
5501 3146 Chrome/Black, Cherokee, Comanche, 1988-89
5501 3146 Chrome/Black, Cherokee, 1990
5501 9667 Black/Classic Black, Comanche, Cherokee "Limited" 1988-89
5501 9665 Black/Dover Gray, Comanche, Cherokee "Limited" 1988-89
5502 0262 Red (Coded "BE"), Comanche, Cherokee "Limited" 1988-89
5502 5215 Black/Dk. Vivid Red, Cherokee, 1989
5502 2112 Black/Pearl White, Cherokee, 1989
5501 3145 Black/Black, Cherokee, Comanche, 1989-90
5AF9 6JX8 Black, Cherokee, Comanche, painted body color, 1990
5AF9 6JW7 Bright White, Cherokee, Comanche, painted body color, 1990
5AF9 6JM9 Dark Red, Cherokee, Comanche, painted body color, 1990
5AF9 6JS3 Dover Grey, Cherokee, Comanche, painted body color, 1990
5AF9 6JB8 Midnight Blue, Cherokee, Comanche, painted body color, 1990
5AF9 6JE4 Colorado Red, Cherokee, Comanche, painted body color, 1990
5503 4044 Black 1991-92
5505 4945 Black 1993
5503 4046 Bright
NOTE: The following Grilles are Black with body color indicated.
5BL2 6KW7 White
5BL2 6KX8 Black
5BL2 6KS7 Silver Metallic
5BL2 6KE9 Dark Cordovan
5BL2 6KE4 Colorado Red
5BL2 6LB8 Midnight Blue Met.
5BL2 6MC3 Blue Metallic
5BL2 6MR4 Graphic Red
5BL2 6MQ2 Turquoise Met.
5BL2 6MC9 Jewel Blue
5BL2 6LG5 Hunter Green Metallic
5BL2 6MV4 Light Champagne
5BL2 6MJ6 Khaki Met.
  • 1 month later...
Wow, I never saw this until now.
Yes, I did piece that one together. This setup is what I know as the "7 piece" front end as there are 7 parts to the setup including the grille. It seems to be found on all of the years that were prior to '91. I believe that the 10 slot grille was stock until '87, the 8 slots replaced them until '97. My '88 came with an 8 slot and I swapped it onto the truck. The stainless/chrome trim around everything was swapped on as well.
The 10-slot grille was used from 1984 (XJ) through 1987. The grille itself was changed to 8 slots in 1988 and continued through 1989. In 1990, the grille remained 8 slots but the entire grille and header assembly were redesigned to use fewer parts. The trim strip above the grille and headlights, which was a separate part (three separate parts) on the early ones was integrated into the grille and headlight bezels beginning in 1990.
The front end in that photo could be made up from 1984 through 1987 parts.
What parts do you need? I've got lots of the grille parts, but I myself am still on the hunt for another good header panel. I hope to find one in these upcoming weekends on trips to local yards...
I was going to give you a heads up on this, but figured you'd find it.
Just didn't know it would take this long! How the heck did you find this?
Rob L. :cheers:
I was doing a search on headlight upgrades (Headlights are pretty weak on the '90) and this came up in the search. :dunno:
