shawn Posted December 27, 2010 Share Posted December 27, 2010 cleaned out with gumout, new tank, fuel pump, fuel filter. air cleaner is good. it's been very low on power -then the next day is good again - then the cycle repeats itself every day or so. idle changes too. ????---all help greatly appreciated. Link to comment Share on other sites More sharing options...
mnkyboy Posted December 27, 2010 Share Posted December 27, 2010 How old is the o2 sensor? Link to comment Share on other sites More sharing options...
cz777 Posted December 27, 2010 Share Posted December 27, 2010 please don't laugh but this alcohol in the fuel as been a pain with o2 senors ,injectors too plus some intake gaskets ,fuel pumps etc in other words hell on the where fuel touches... Link to comment Share on other sites More sharing options...
Pete M Posted December 31, 2010 Share Posted December 31, 2010 have you tried watching the fuel spray pattern on the fuel injector? done a general tune up lately? Link to comment Share on other sites More sharing options...
shawn Posted January 11, 2011 Author Share Posted January 11, 2011 did all of what i had first mentioned, plus plugs and wires. thought i had solved it with the wires but it came back today. not looking forward to trying the 02 sensor this month due to its high cost. Link to comment Share on other sites More sharing options...
shawn Posted January 13, 2011 Author Share Posted January 13, 2011 plus 3 other things: - sometimes it seems to do it when its been driven a long ways. it will just suddenly lose power. but will continue to run fine at low rpms ( and idle fine). - quite often the idle speed will continuously change. -but not all the time. - the heater only blows from the defog vents. ( vacuum leak?). Link to comment Share on other sites More sharing options...
Pete M Posted January 13, 2011 Share Posted January 13, 2011 if the heat only comes out the vents, then you likely have a vacuum leak. that's where I would focus my efforts since it could cause engine issues also. Link to comment Share on other sites More sharing options...
brdhntr Posted January 14, 2011 Share Posted January 14, 2011 sounds like a vacuum leak that may be from a loose, not broken, vacuum line. another thing, it could be a bad coil. if the coil is bad, it can be affected by heat, vibration, etc, that can cause a intermitent problem. if you want to replace the coil, just buy an accel rather than oem. the oem 1 will cost more and puts out less. the accel coil can be had for 30-45 bucks. Link to comment Share on other sites More sharing options...
shelbyluvv Posted January 14, 2011 Share Posted January 14, 2011 Sounds like a bad MAP sensor to me. Link to comment Share on other sites More sharing options...
