GummiBeer Posted November 26, 2006 Share Posted November 26, 2006 Hey guys. i just ordered a new fuel pump assembly and tank from NAPA. the problem is the pump won't seat in the tank. Everything i checked, tells me that its the right tank and pump assembly. the pump catches on the pan inside the tank....almost seems like the pump is reverse. but its the one listed for the truck Any ideas??? Link to comment Share on other sites More sharing options...
bdjr Posted November 27, 2006 Share Posted November 27, 2006 what year and tank size. on the 86's there was a tsb that came out that stated that the 'float' on the arm of the sending unit needed to be reversed. this is because the sending units are for 16 gallon tanks and they started to use 23.5 gallon tanks. it says to simply pop off the float and reverse it to make it fit. hope it helps bill Link to comment Share on other sites More sharing options...
GummiBeer Posted November 27, 2006 Author Share Posted November 27, 2006 its on a 88 4.0l with a 6' box...its a 16 gal tank. To me it seems the the pan on the bottom of the tank is on the wrong side or something???...but i'll check the float idea, but i don't think thats it Link to comment Share on other sites More sharing options...
Bounty Hunter Posted November 27, 2006 Share Posted November 27, 2006 I had to move the fuel pump around some on my shortbed '88 to get it to seat correctly in the bottom of the tank. Link to comment Share on other sites More sharing options...
jackel18 Posted November 27, 2006 Share Posted November 27, 2006 Bounty Hunter said: I had to move the fuel pump around some on my shortbed '88 to get it to seat correctly in the bottom of the tank. :agree: i had to do the same. Link to comment Share on other sites More sharing options...
jeepdoggydogB Posted November 28, 2006 Share Posted November 28, 2006 I had a similar problem with Napa, I went as far as to purchase a new gas tank off of ebay to confirm that the pump was wrong. I then picked one up from a wrecking yard and it installed with no fabbing, just went right in. I bought 3 pumps from carquest, napa, and ebay, all did the same thing. I have the 18.8 gallon tank with the 6 ft bed. Link to comment Share on other sites More sharing options...
GummiBeer Posted November 28, 2006 Author Share Posted November 28, 2006 will the 23 gal tank fit in the 6 foot box where the 18 gal tank is??? Link to comment Share on other sites More sharing options...
Pete M Posted November 28, 2006 Share Posted November 28, 2006 Short answer: no. But if you want 5 more gallons, it's easy to strap on a military jerry can. :D Link to comment Share on other sites More sharing options...
comanchedude Posted November 30, 2006 Share Posted November 30, 2006 GummiBeer said: Hey guys.i just ordered a new fuel pump assembly and tank from NAPA. the problem is the pump won't seat in the tank. Everything i checked, tells me that its the right tank and pump assembly. the pump catches on the pan inside the tank....almost seems like the pump is reverse. but its the one listed for the truck Any ideas??? Well I am glad to see I was not the only person to run into this deal I bought a new tank and used the original sender till it started to leak from rust so I bought one from a fellow club member and it would not seat just as you describe What I notice is the original has a longer "arm" about an inch or so and sets the pump and sender out in the middle of the tank, now the pump I got used had a short arm and would hit the baffle? (There are different senders that’s a fact) So I had to get creative and fix my original unit and lucky me I was able to make a long term repair to the unit and reuse it I would like to know why there are different length senders but the same replacement tanks? Link to comment Share on other sites More sharing options...
