AX15 Identifying
At the P&P this afternoon I saw a transmission in a 1989 XJ. The Jeep had been rolled. I couldn't get underneath it and there was too much stuff on top to see well enough for identification. The motor was gone so it's a clear shot looking at the front. It has internal clutch. What to look for to insure this is a AX15, not a BA10 when all you can see is the front. Bell housing is still attached. Jim
If you can see behind the bell housing at all....the BA10 splits down the middle:
Whereas the AX15 is bolted together in two segments:
Not sure of the bell housing differences, but you CAN see the bolt patterns for the bell housing above, and that may help you with the ID.
yup, peugeot case splits into a left and right half. the AX-15 splits into a front and back half.
hard to see from the photos, but the ax-15 has a broader and rounder bolt pattern from trans to bellhousing. peugeot has a skinnier and weird shaped pattern.
If you had taken a photo, I could tell ya for sure, but it's hard to explain.
AX-15 on the left.
Found me a AX15. Heading for the JY first thing in the AM. Got a brew standing by if anyone can see there way to come help me. The driveshafts already gone so I'm just gonna undo the 2 bolts on either side and take the whole thing, Transmission, transfercase, crossmember and shield plate. Thanks guys.
Got it. It's a good thing I didn't know anything about AX15's or I wouldn't have. It came out of a 1988XJ. If I had known AX15 didn't come out until '89 I wouldn't of even looked. It was obviously swapped in by a previous Owner. Can anyone help me identify the year and what transfer case? ID code on the trans reads 00?0 157. $150 and 2 hours of my time.
Interesting skid plate set up. Obviously home brewed but looks like it could do the job.
Drive shaft label
Transfer case No. Sticky label is missing.
  • 6 months later...
I have a friend who knows nothing of his 91 XJ. It's has rear end problems and has offer the Xj to me for parts if I can use it. It is a 91 XJ with the 5sp and 4x4 set up. Since it is about 100 miles from me I can not identify the trans from his pic's, but I am assuming it is an AX15 with matching 231. Am I safe here? Anyone able to give me some advice on if this would be a good donor trans so I can get rid of the puejot. I was told the clutch will fit both but any info on or recommendation on a "new" clutch and brand for the price? I have no problem moving up to a better clutch if need be same is true for the slave. . All input appreciated. Needed ASAP Thanks,
James and Sugarfoot ,
Denton TX 88 MJ Red Pioneer 4.0 4x4.
